Hallo y'all. I was wondering how te stock r34 brakes , with decent lines, oil and pads, perform for trackday use?
Do they deliver enough stopping power or is it advised to upgrade to gtr brembo's or evo calipers ?
I'm on the point to getting my gtt on the road and have to change my brake pads and discs and i don't want to spend money on something i have to change soon because it isn't enough ... [emoji3]
GT-t brakes are decent (enough).. being 310mm in diameter.
I used to run stock R33 GTS-t brakes, 296mm in diatmeter and they were decent for a 330kW boat at Wakefield Park. Coupled with Project MU HC800+ they could do about 4 laps before showing signs of fade.
When I mean fade, brakes would still work for 10 laps but require heaps of pedal effort.
I've since upgraded to BREMBO calipers with Intima Type-D (as I sell them haha)... car is destined for the track 30th May for a shake down.
I upgraded my C34 Stagea (which is probably heavier than your car) to GTT brakes with specially made pads from RaceBrakes and they worked well on the track. When I upgraded to an RB30 with a bigger turbo I felt the need to upgrade again.
And where you dritving street tires or semi's
? [emoji3] [emoji6]
Yeah they're fine but eventually you'll want more, as always.
I've got a $1,000 budget set up in it's been fine for Sandown and Calder in my full weight R34 sedan, though I'm not a brave braker (yet).
DBA discs, Remsa 650C cheapie pads, braided lines, high temp fluid, BMC stopper.
Details here: http://www.sau.com.au/forums/topic/448613-r34-gtt-brake-improvement-without-breaking-the-bank/
I ran last two track days with fresh R888R real semis with a skinny 225/45R17 square setup, no issues with braking performance (except uneven pad wear but that's a different story: http://www.sau.com.au/forums/topic/463353-post-track-day-qs-rotor-wear-gearbox-oil-ps-pump-manifold-nuts/ ).
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
