Forecast is looking good for this afternoon. Anyone still keen?
Yep - as long as its not raining.
Been 4 months since I had the car our so keen as mustard.
First stop will be Osi Park United to fill out on E85.
I'll check in here around 12 to confirm 100%.
Dan
  • Like 1
Hi all I'm Mark long time stalker
i have a JDM4WD but obsessed with GT-Rs my wife h8s me when im dulling as i drive past one or even wind down the window n turn off the radio just for my brain to sizzle like bacon on a pan listening to a RB.
Eventually ill buy one but few years away.
Would love to meet n great you guys.
If you doing a dinner thing or track i would be excited but kinda embarrassed to go as i got nothing to show.
Ill be in perth this comming week ;)
  • Like 1
Hi guys if I get some time I'll try organize some small meet or mini cruise the forum activity seems to be slowly going up.
I had wanted to do a small meet but owning a GTR is sometimes hard and doesn't leave much spare time
2nd to the dumb C U N T that gave this thread 1 star come on what have you contributed to the group?
Edited by RB335
  • Like 2
Hey Hank is this still on ? Let me know what's the plan - meet up or not doesn't bother me.
Thanks
Elle
Missuz hasn't chosen a bar yet.
But we will be somewhere... sometime :yes:
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
