Hi guys,
I know it isn't a skyline but thought it would be worth a shot posting up on here in the hope somebody wants a track ready car that isn't a skyline :)
Quick run down on the specs:
1.6 engine which has been turbocharged with custom kit using T28 dual ball bearing turbo.
Full set of inconel locking studs
Full 3 inch exhaust from back of turbo all the way through, no cat only running a straight through muffler. 3 inch cat will be supplied if car is sold as I have it.
EMS stinger ECU running full custom tune done at CRD, car makes 140kw at the wheels, have dyno sheets to prove.
Full NB8B brakes, front and rear with brand new Winmax race pads.
Whiteline adjustable swaybar on the front
Yellow speed coilovers.
Brown Davis roll bar
Hardtop
15x8 banzai wheels running full slicks (245/50/15)
Garage vary front lip
Works engineering oil cooler
Works engineering fuel pressure regulator. Can supply a full set of 550cc injectors also.
Mazdaspeed fixed back race seat (Very light)
6 point harness
Fully stripped out, except for the dash.
That's all I can think off right now.
The car has a heap of potential and has done a 1.08 at wakefield on crap semi's and running the standard NA brake setup. Can easily run a 1.06 or better with the bigger brakes and slicks.
Looking for $10,000 which is slightly negotiable.
Call or text me on 0414 303 233. located in Liverpool area Sydney.
The pic that has the bigger guards is the most recent. Have a heap of spares that I can throw in including spare harness and spare race seat.
Thanks
Joe
https://www.sau.com.au/forums/topic/464256-trackrace-only-turbo-mx5/
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
