Lose response make like 10kW up top...
But last I spoke to Alex they've made a smaller version of it so you don't lose as much response.
Regardless of the old or new Plazmaman plenum, they out perform the likes of GReddy, etc.
What manifold would you rate in that case for rb25det?
What are you goals? To be honest stock is awesome.
Unless you're starting to make solid power, by that I mean over 400kW then time to get bigger
Yeah mate, sitting on 340kw atm, about to go to e85 and aiming for the 400 mark, but probably won't hit it.
As mentioned above, I put the freddy on because I think the standard pipe is ugly. Will go a genuine greddy on the 25/30 though.
^ if money permits, go back to the stock runners and run a Plazmaman plenum.. you'll gain some more low down as you're using the OEM runners.
If you want in future, send me a PM I can get Plazmaman gear at decent prices.
OK, thanks .... seems there is no dyno available.
From the design of the plenum it looks like the manifold might introduce some sort of lag since the bulbous design.
Not sure if it's worth the trouble of installation then.
Hi,
It that confirmed? I could not find it on their website ..
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
