Hi All,
So recently I have noticed that my driver's side chair has started to creak when I shift my weight on it or go over bumps etc.The noise seems to be coming from the rear of the chair.
Has anyone else experienced this and knows what the cause and fix is? Its been like this for about three weeks and is driving me insane!
Cheers.
https://www.sau.com.au/forums/topic/464299-2008-v36-sedan-creaking-chair/
  • 3 weeks later...
Hi Froggy,
Did you manage to get a solution with this?
I only just found your post and thought your problem sounded familiar. However slightly different that the creaking sound was actually coming from the rear end. I know you prob think im barking up the wrong tree here but maybe you can work out if it is in fact your chair thats making the noise by fiddling with it from the rear seat?
If it is in fact from the rear end (axle or suspension area) then let me know, cos I just had mine fixed!
Good luck!
Hi Froggy,
Good luck!
Hey mate,
I have not had a chance to look any further into it yet. Ill take a look on the weekend but i'm pretty sure its the chair.
Update - So it definitely the chair. Sitting in the back and moving the front chair I dont get any creaking. When im sitting in the chair, the further I put the seat back the less the chair creaks to a point where it does not happen at all (the seat is almost all the way back).
Any ideas?
Edited by froggy88
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
