Hi all,
I'v searched both on this forum and on the internet generally and not found a definitive answer to my set of questions.
There is a lot of discussion out there about the TE37 wheels on teh AWD Sytageas but not much at all about them on a RWD Stagea.
My car is a Series 2 C34 Stagea RWD Auto. I want to fit Volk TE37 wheels but they must have the nice concaved look.
If I go for 17s or 18s, what width and offset of wheel could I use ?
Will that offset on a TE37 have that nice concave spoke look ?
https://www.sau.com.au/forums/topic/464680-volk-te37-on-rwd-what-size/
If installed in the right offset, the TE37 spokes bend inwards going from the outside towards the middle. Thus giving the concave appearance which looks nice... see photos attached
That really depends on the thickness of the hub itself. I've seen quite a few wheels with the same width and offset but instead of concave spokes or a bigger dish, they have just had a bigger hub.. I can't tell you why they do this as it makes it a pain to get a full set or 2 full sets of identical wheels.
The reason why i said this, is the te37 could be one of the brands?
staggea1.jpg?w=1000&h=666
The top car at least is a 260RS and will be AWD
Hey Bob what were your track wheels? i remember them being 3 piece and multispoke. Can you post a picture? I really liked them.
Bought them second hand off a drifter - can't remember the brand sorry...
Here ya go - 5 minutes on Google and here's what you are after - they are called TE37 Ultra Evolution Track edition (with what they call "inverted" spokes) - nothing to do with offset - they are available in a range of sizes and offsets. I suspect they will cost an arm and a leg each:
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=TE37ULTRA-TE
If you had bothered to click on the Link to Rays Engineering that I gave you you will see that this statement is incorrect (as is your statement that you know the model of wheel you are after). It is the particular model of TE37: "Ultra Evolution Track Edition" that gives them the inverted spoke look that you are after - nothing to do with offset - as i have already told you they are available in a full range of offsets ALL of which feature the "reinverted spokes".
17 or 18 x 8in or 9in will fit. For offset I have no idea for your car - for mine it requires different offsets front and rear.
According the the web site they only come in a 20" rim size for the ultra track edition and 19" and 20" for the Ultra
Yes quite right. Which confirms my theory that the wheels on the 260Rs cars above are Varrstoen copies (not forged but cast) which do come in 17 18 and 19 inch. Others making similar knock-offs include Koya and Rota.
I did bother to look at the link.
Reading through it and finding that, the "track edition" is not available in rim size 18" confirmed to me that it is not the only edition that can give the inverted spoke look.
The photos below are of a car which has Volk TE37 in 18" ... not replica. These photos show the wheels to have that inverted spoke appearance which I am after.
Edited by ceejay
I found a couple of the TE37SL variants have that look.
That is right Sir. That is exactly what I am saying too. There are several of the TE37 versions that have the inverted spoke appearance.
The spokes look more and more concave as the outer edge of the rim moves further and further towards the outside of the car, compared to the position of the hub. negative offset or the smallest positive offset.
What I want to know is, say for 17" and 18" wheels, (never mind what brand or style) what is the width and maximum offset usable, which will bring the edge of the wheel closer to the outside of the vehicle but still not cause fouling with the wheel arches.
Edited by ceejay
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
