Good day everyone, my name is Zaid I'm new to this sight. I'm hoping some will beable to assist me. I have a skyline r34, it has the rb25det neo motor, I have an issue that nobody can seem to solve, please can someone advise or give help. I'm from south africa and we don't get the skyline this side, so I had to import mine, so not many guys have experience in fixing this car. Firstly the car was stock.when I came upon this issue,the car would loose power like it dropped a valve, but it would only happen every now and again, I had it checked out I was told my spark plugs were wrong so I did research on sights got the right plugs and even gapped it to 0.8mm the car ran fine for awhile then the same issue returned about a month later, I then replaced the coils, thinking one or a few must be faulty , once again it worked for a month then the problem returned, some said my earthing of the car was not right. I sorted that out but the problem was still there, I then changed my injectors found out one was faulty. The car worked fine for about 3 months then the issue came back and shortly after that the piston melted and the conrod cracked through the block I replaces the motor and put a spitronics management system in now my engine light doesn't want to go off and the new motor is giving the same problem. I don't know how to fix this issue. Please some advice would be great. I'm not to clued up on some of the terms you guys use so please reply like you righting to a person that knows nothing about cars. Thanks in advance
https://www.sau.com.au/forums/topic/464717-need-help-please/
  • 3 weeks later...
new motor, new coil packs, new ecu, new plugs, but same prob... maybe its somewhere in the fueling, fuel pump, fuel lines, fuel filter, or even the fuel itself.
If you have a buddy with a wideband, and if ur ecu (not familiar with spittronics) can do datalogs, this would be quite handy to help see what is actually happening when the power loss kicks in.
if you melted a piston i believe you could have a severe fueling issue or spark. and you covered alot on spark...
  • Like 2
Thanks Dev, I did reply a while ago but I.don't see my reply here, not sure why, anyway it's a stand alone management, it possibly could be fuel but if so, won't a dyno pick up that. I notice my spark plugs die very quick, sometimes only lasts 3 months if I replace them then the power returns. I'm out of town for awhile so.I won't beable to check.thoughs ideas at the moment, but I'll check on the fuel
if the car was dynotuned, then yeah definitely they should have picked up an fueling issue if it was lean or rich..but since you mentioned the problem comes and goes... perhaps that is why nothing was detected...
a bad fuel pump and/or fuel pressure regulator could make the car possibly run lean, maybe that was the case with the old motor melting the piston.
    • The drop shipping isn't the issue I believe, the issue is that a US business is getting stuff manufactured in China, and then selling them, this gets reported in their taxation, thus, I believe, the US government still wants its pound of flesh Whether it is the 10% tariff, which I'm happy to pay to play with, or the 115%, which would be a deal breaker Hopefully this gets sorted sooner rather than later as impatient Mark is impatient...LOL
    • Amazing build thread mate. I wish mine was still on here too. Love the seats. How did they wear overtime? Great to see you are still working on it bud.
    • Drop shipping isn't hard for them to sort out...
    • I bought it for a forever car bud. Was really lucky. It's one owner and kept fully serviced and immaculate. Kills me to modify it but will keep it to the engine and GB only. Body will stay stock and intend to keep all the parts. It's a Silver with factory Altia kit. My mate and I are building it together in the garage. It's currently an auto and just bought new manual GB and parts from Michael at Kudos. They've been great.
    • So, as for the intake parts, part supply/delivery is currently problematic  As the parts are not made in the US (probably China) new tariffs are making things slow to happen, thanks Trump The joint I am getting the intake parts from, FAB9, are in the US, typically they are delivered to the US then sent out from there to, well, here, or wherever  FAB9 are currently looking at shipping directly from the supplier to avoid tariff hits,  so now I'm waiting until that little chestnut gets sorted out My impatience is blossoming nicely
