Hi all,
I purchased a neglected C34 series 2 Gtagea a few days ago. Non turbo RWD auto.
It had 2 burnt coil packs, bad plugs etc which I sorted out.
Once I did the first test drive in the car, it was apparent that the transmission is always in 4th gear (I think it's 4th)
It certainly does not start off in 1st and it does not perform and gear changes at all. Feels like it's always in 4th.
Sent it to the local Nissan dealer and they have plugged it onto their "consult" and apparently it says there is a fault with a solenoid.
However, before they look inside the transmission pan, they want to ensure that the external wiring to the transmission is all good but they don't have the wiring diagrams for this car.
They wanted me to try and source the transmission related wiring diagrams to make their job easier.
Please point me in the direction if these diagrams if any of you have access to them.
Thank you !!
https://www.sau.com.au/forums/topic/464795-transmission-wiring-diagram-please/
umm I guess you must really like that dealer.....personally I would not be OK to pay the premium of a dealer mechanic to have them ask me for info about their car. I wouldn't mind helping a local mechanic if they asked the same question because I don't pay more for them to have this sort of info (yes I get it's not locally sold....but still....)
Anyway I have the PDF manual if you want it.....about 3,200 glorious pages in japanese.....send me your email address and I can send a link
BTW very unlikely to be a wiring problem if 1/ the trans doesn't work, and 2/ consult says why it doesn't work. I'd just change the faulty solenoid and see what happens
i believe if you unlug the brown plug for the auto it will be locked n 3rd? i have not tried this, but read that's what a lot of tuners in japan do.
find the brown plug on the drivers side under the battery and trace the wires or see if it still plugged in
Hey duncan can u send a copy to [email protected] for me. Hopefully its not to big for gmail!. Cheers
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
