  On 25/05/2016 at 8:04 AM, Trex said:
But in all seriousness. I don't use any bov, never will again. They all leak and cause serious lack of power around 10-30% throttle.
That's just my personal opinion
But I thought they help with transient response.
I would expect the stock BOV to open when boost in the cooler pipes, purely because of the softness of the spring
An aftermarket BOV adjusted to a hard setting is more likely to stay closed
The stock BOV's do have that little bypass hole as well, wether that makes a difference or not
BOV's work off pressure differential. Imagine for arguments sake the spring is worth 2psi, so with the car boosting it has 10psi on the cooler pipe side and 10psi on the top of the valve, so with the spring 12psi on the top, obviously 12 beats 10 so BOV stays closed. Close throttle, vacuum occurs in the manifold so now you have 10psi on the cooler pipe side and -10 on the top of the valve + 2psi so therefore -8psi
With the boost/vac line removed, you only ever have the 2psi of spring pressure holding it closed, so as soon as there is any more than 2psi in the system the valve will open
These are just rough numbers, but remembering how soft the stock BOV was to open by pushing it in with my thumb, I would suspect it would stay open alot
So really what you should have is a whoosh of air then possibly a small flutter at the end when the spring overcomes the valve. Although then you have to think about the effect the low pressure/vac that is present in the recirc pipe is having
  • Like 1
Pretty sure Tom said he's using an auto, but with a manual yeah when you get off the throttle when changing gears the recirculation valve will stop the compressor from stalling.
Even more so if the diameter of the diaphragm is lager than the seating surface of the valve.
Hmmmm. I am in 2 minds atm. In a GTR I have the BOVs venting in the guard and considering removing them altogether So the question is whether or not I will see a noticeable change in transient response on part throttle. Any advice would be great.
I blocked mine off this arvo and noticed zero difference, 14 psi, breed valve, auto trannie. Have you tried lubing the shafts on the rec-valves with some molly grease? mine used to stick a little open until I lubed it.
Not much Sutututu either, stock intake pipe and airbox.
Did some quick calculations on my rb20 rec-valve,
Valve seat is 1" diameter = 0.785² inches x 14 = 11lbs
Diaphragm is 2" diameter = 3.14² inches x 14 = 44lbs
estimated spring pressure 10 lbs
so when at 14 psi boost, there is 44lbs pushing down from the diaphragm, 11lbs pushing up on the valve face, then add another 10lbs down for the spring
so thats about 54lbs down compared to the 11lbs pushing back up from the 14psi of boost.
To see how that changes at intermediate throttle positions you would need to put another pressure gauge before the butterfly in the throttle body, needless to say as soon the plenum approaches atmospheric pressure only the spring will be holding the valve closed.
Please correct me if my physics is off ;)
Edited by Missileman
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
    • I got sick of thinking about batteries so just kept buying chargers. I've got a ctek (racecar), a "noco" thing from supercheap (tow car with 2 batteries), and an old "SupaCharge" branded lead acid thing (farm ute/mower) and will need 1 more when the Silvia gets a battery again (if the 86 stays).  I always make sure the charger itself is in free space/away from car etc, just to be sure.
