Hi guys,
I have my eye on a front cut from a 2000 stagea and would like some information regarding the difference between the RB25DETs in them and the ones found in R34s.
I have been told that because they are auto, they have less power. Is that just a simple tuning problem cos they're auto?? Or is there more to it??
How hard are they RB25DETs out of the stagea's to transplant into a manual R34?? I know that you need to change the sump and oil pickup, and that the loom is different. Can anyone expand on this?? Is there an easy way to get around these problems??
Thanks in advance,
Brett
Hey Brett,
The RB25det in the R34 Skyline is the NEO version, VVT type. I have a 97 mod staj with the r33 type 25 motor. The reason that they are not as quick is a simple weight issue. The Staj is a bit of a porker carrying 1650kg dry. How much is fcut?? Are you trying to change the R34 into a 4wd?? Big job!
Cheers m8,
Ken
The front cut also has the NEO version of the RB25DET. I am looking to transplant this into my RWD R34 and need to know of any hassles before hand, so that I can deal with them quickly and get my car on the road ASAP.
I know that to transform the cut from AWD to RWD, you need to change the sump and pickup, but other than that I have not been able to source any other information. Any ideas??
Anyone?? :confused:
  • 3 weeks later...
i have a stagea engine in my r33 gts4 and it is exactly the same as a rb25det, except that the sump you will have to change because of the 4wd drivetrain in the stageas',loom you can get away with the standard one because i think the stagea loom has the fwd linked into it. im actually taking my stagea engine out and selling it if you interested, because im putting a rb25det in so ill swap the sump myself... pm me if your interested
Thanks specialk,
I already have a stagea engine (Neo RB25DET) that is going in on Wednesday. Thanks for the info on the loom, too. I have heard that it shouldn't be a hard swap, but needed to know if there was any major differences i.e incompatible wiring harnesses etc.
What was your reason for swapping from the Stagea RB25DET to another RB25DET??
i work with boostd (the one who's car got written off) and we are throwing his engine into my car. just had more work done to it.
you are converting your car to RWD? or was his a 4wd rb25det as well?
as far as im aware, the 2wd sump will bolt onto the 4wd block, but not the reverse
Yes. Apparently the 2WD sump bolts onto the 4WD engine but not the other way around. I hope so cos I need to transform the stagea cut from 4WD to RWD.
Does anyone know what differences there are in the wiring harnesses for the stagea RB25DET and the R34?? As much info as possible would be great!!
the 2wd uses a different set of "bolt holes" in the block for attaching the sump
the 4wd block has 2 sets(to suit 4 and 2), the 2wd only has the holes it needs (i think)
Correct :D
  • 3 weeks later...
Seems like a waste of a perfectly good 4WD engine. They are hard enough to come by at the best of times , without ppl converting them to RWD only. I just transplanted one into my R32 GTS4, because it's the only upgrade (short of a 26).
Why not let some poor soul with a R33 GTS4 use it for his upgrade? You can use any RB25DET in a GTS / GTSt.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
