Merging my various for sale threads into one, here goes:
1. For sale a full set of 6 Yellow Jacket coil packs to suit R34 GTT, GT, and Stageas with RB25DE/T Neo – $150
2. For sale an R34 GTT coupe steering rack with around 80,000kms on it, off a 1998 car. – $90
3. For sale used leaky Driftworks braided oil cooler hoses with crimped AN10 fittings, for spares – $50
4. For sale R34/R33 transmission parts – $100
See below for details. All parts in Melbourne near Essendon, pick up preferred.
1. For sale a full set of 6 Yellow Jacket coil packs to suit R34 GTT, GT, and Stageas with RB25DE/T Neo.
The Yellow Jackets were installed in late 2010 and have about 45k on them.
These coil packs are not new or perfect, but run ok. I reckon these would suit a low boost car fine (I'm running 20psi+).
Reason for sale is changing over to Splitfires.
Full disclosure: I've always had a niggly misfire in the car - hiccups on idle - and looks like it's still there with the new Splitfires too, maybe a touch better, go figure..
The resistance values are 1.53, 1.54, 1.51, 1.57, 1.54 and 1.57 so it's a very even set.
Asking $150 ono a new set is of Yellow Jackets $400 shipped.
Melbourne inner north, pickup preferred. Can post at buyer's expense.
PM if interested, cheers.
Decent condition, see photos below. All dust boots are in good nic and there's very little play in the rack ends so should be good for spares, too.
I bought this off another forum member but it wouldn't bolt up in my R34 GTT 4door, so there must be a difference between the coupe and the sedan? You're welcome to take any measurements before purchasing.
Asking $90 ono. Pick up only due to size, inner Melbourne.
Things to note:
  • Hose lengths are 115cm and 135cm
  • This is heavy duty braided hose about ~25mm outer diameter
  • The AN10 hose fittings for each hose are 90 degree elbow at one end and a straight one at the other. The fittings need a good clean.
  • Caveat emptor: These hoses leak at the straight end, so you'll need to replace those two crimped hose end fittings. Standard Speedflow etc. AN10 fittings won't do because this hose OD is larger than the Speedflow AN10 hose.
Not worth much so let's try $50? Pick up only, Melbourne inner north.
Note: The photo above is of the whole oil cooler kit, new – this ad is for used hoses only
RB25DET manual transmission parts:
$50 - R33 Series 2 fuse box to gearbox wiring loom
$40 - R33 GTS-t manual coupe tail shaft rear part
$20 - R34 turbo gearbox clutch fork (pull type)
RB25DET automatic transmission parts:
$25 - R34 GTT auto brake pedal
$40 - R34 GTT auto sedan tail shaft front part
Or $100 for the lot of trans parts.
Notes:
  • Like 1
  • 4 weeks later...
Coil packs sold.
All other items still available, prices ono.
  • 3 weeks later...
These are still available:
See original post for details. All prices ono.
Here's some photos of the actual Driftworks braided oil cooler hoses:
I found another item whilst clearing the shed today:
5. Davies Craig 678 Hydra-Cool Transmission Oil Cooler - Universal, 8 Cylinder – $80
This is the core only, in good working condition. I had it on my auto for less than a year until the car was converted to manual.
These are also still available:
  • 1 month later...
Sold:
  • 1 month later...
  • 4 weeks later...
Sold:
1. Coil packs
2. R34 GTT coupe steering rack with around 80,000kms on it, off a 1998 car. – $90
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
