My car was in an accident recently,  took a punt in front. 1997 GTS-T  Series II automatic.
Both driver's and passengers aibags deployed.
What part's do I need to require to fix this shit-suation?
Can you use second hand parts?
Should I  leave my battery disconnected until they're fixed?
Basically the proceedures to repair the car....?
Or can anyone recommend a good repairer in Melbourne?
I figure the ECU will require some sort of resetting procedure?
Nissan Genuine prices are outrageous.
Just trying to cost up the repair  atm
Edited by mercyseat
Don't know the answer to your question but I have seen cars written off because of the cost of replacing the airbags. I would suggest checking out some non franchised Nissan workshops for ideas.
you will need
both airbags (given)
steering wheel clock spring
undeployed airbag module (under centre console)
undeployed front seatbelts
some instances, you may need new front crash sensors
2 hours ago, Dose Pipe Sutututu said:
you will need
Thanks Heaps!
Car WAS an economical write-off so not a complete Stat Write Off luckily.
How do you know though that you have the correct second hand airbags / clock springs etc? Are there specific serial numbers?
I just spoke to one guy in NSW and he said when you use second hand parts you have to program them into the CPU also.
But until they dial into the CPU the full diagnosis can't be determined...
I reckon the crash sensor is a given too seemingly the damage at the front. Don't even know what it looks like OR where it's located?
I found a guy who will quote to repair but he wants the other damage repaired first which makes sense.
Sourcing other parts as we speak...bonnet, headlights, front bar, fog lights, radiator, radiator fan schroud, radiator condenser, windscreen....etc etc
It's gonna be a slow rebuild.
Edited by mercyseat
Whoever spoke to you is telling you fibs.. it's an old car the airbags are not coded like new cars.
Just get everything from a S2 GTS-t or S2/S3 GT-R they're the same.
Older S1 or S14 S1 or 180SX have the airbag module built into the steering wheel.. newer one such as anything with dual airbags all run off the module undernealth the centre console. It's held in by a security torx bolt.. (star shape with a rod in the middle, bunnings/repco/supercheap have them... can't recall on price).
  • Like 1
Cheers
Just placed an ad in the wanted to buy section.
Only got the  car home yesterday,  gonna rip apart the front and go through the parts required.
Will try to buy an entire dash I think. Battery is dead from sitting untouched for a month, should i just disconnect it whilst I'm taking the front apart?
Was thinking of recharging it.
Cheers
EBay and Gumtree are your friends for a lot of parts. There was a 33 dash for sale recently for like $50 on eBay. Why do you want to replace the whole dash. Is it damaged from the air bags deploying?
Bummer, yep I think from what I can see passenger airbag could have caused some damage, drivers one tore through the steering wheel centre section. No idea if it will turn over if I dismantle the centre section from the steering wheel. Either way the dash has to come out to repair the passenger airbag I've been told.
No bloody idea how to remove the stuffed airbags.
Passenger bag casing won't re-close.
Not sure how to dismantle the centre section of the driver's airbag. If I remove it,  will I be able to drive the car?
Just spoke to Nissan.
Apparently if you want to replace the old airbags with secondhand/salvage one's they must be "stamped" OK from someone who's qualified in testing the airbags.
You won't pass a roadworthy if the second hand one's are not tested.
So leaving these off my second hand shopping list for now.Will find a proper airbag repairer to source/do all the work after the rest of the car is up and running
TBH.. if you're going down that path, you're better off wrecking the car/selling the car and getting another R33 S2.
Nissan will tell you what is best practices... I would personally replace it all myself, however that's me personally.
I plan to sell the entire wreck if I can't fix it myself or it becomes a headache.
Still got a good solid engine with only 96,000kms on the clock and gear box to match, rest of the car was mint pre accident hence why I'm trying to fix it up.
There is no time limit here as I have another car moreso a project. I was thinking of buying another entire car and pillaging parts off mine, just haven't found anything that matches
my 40th Anniversary model, not many around .
Has anyone ever seen a Crash Sensor or selling one?
4 hours ago, Dose Pipe Sutututu said:
most of the time (from my experience) you don't need to replace the crash sensor.. however on newer cars yes.
Well I bloody hope so that's the case because Nissan advised they don't supply that part anymore. R.I.P genuine crash sensor.
I did note they are willing to sell you  new airbags for ridiculous  $$$, weird but that might be because you don't need that little annoying sensor that deploys the airbags under 30 km's MVA's. Besides the airbags caused more harm than help in my case.
Maybe there's a generic part available otherwise I'm up shit creek.
Or just pillage an entire dash & bags from another 97 S2.
Buying a 40th Anniversary model can be a pain looking for parts. People go on about mainly cosmetics but there is way more differences,  some from R34 eg stock rims are the stock R34 style, injectors upgraded/moved,  seat belt holders, interior stitching, badging, rear wing tail light,  turbo has a nylon compressor wheel,not to mention bonnet/ headlights over all look is sharper. Also midnight purple isn't easy to match buying second hand.. Pre accident the car had more torque and very responsive gearbox. Much more guts than my old 1994. Actually had to tone down as the rear end liked to swing out , was fun to drive.
TBH.. 40th Anniversary isn't anything special.. I had one before, and sold it.. didn't go for much more than a 1996/1997 S2.
If your mind is set on fixing your car, unplug the airbag module under the centre console and start replacing all the airbags, clockspring, followed by the 2x front seat belts. Once that's done, install a new module (make sure the battery is disconnected). Then plug back your battery, then standing in a safe position where the airbags can't deploy and hit your face/head/neck etc. flick the car onto 'ON'.
Check the SRS light, it should come on.. do it's checks then turn off. If it remains on/flashing, then look up the error codes and replace the outstanding items.
"Usually" the clockspring & crash sensors can be reused.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
