Wanted to buy: R33 GTR LM Limited
Currently I have engaged an importer in the hopes of turning up an R33 GTR LM at the Japanese auctions.
Ideally the car will have: 100k or less kms. Prefer original condition, however I would still be interested in hearing from you if you have a modified car.
I'm based in Melbourne, but I would consider any car currently in Australia.
https://www.sau.com.au/forums/topic/465804-wtb-r33-gtr-lm-limited/
Thanks for the link @I gotta R34gtr v-spec, I am having someone (who knows a little more than I) investigate it for me.
If anyone else turns up any other GTR LM Limited's I would still be keen to hear from you. :)
  • 4 weeks later...
  • 3 weeks later...
Quote
This is not important. If anyone turns up an LM in Japan please let me know, i'm searching myself, but others may find things I miss. I have someone in Japan who is willing to look at these for me so all cars are applicable to my search.
@sin-, that's great to hear. Do you have any further details you can give me? A link or where the car is going to auction or it's current location?
Any info would be greatly appreciated.
@sin-, thanks for the tip off. I have asked my contact in Japan to check it out. Funnily enough he said he already had the paperwork and sent it straight through.
  • Like 1
On 9/13/2016 at 9:59 AM, sin- said:
One coming through auction this week 139k 3.5
Took a very long hard look at this car. Apparently had a lot of interest on the day.
The car itself looked good from the outside, but the underside had a coating of surface rust (not a huge) problem, there were quite a few clamps, connectors and other bits and pieces that would have needed replacing.
The real issue was a whole lot of rust surrounding the passenger side suspension upright. The way it was currently it couldn't have been complied before the repairs. Based on suspected work that was needed, I ended up bidding for it with a limit of 2m yen, the car ended up being sold for approx 2.5m yen.
  • Like 1
On 9/17/2016 at 4:14 PM, sin- said:
http://page14.auctions.yahoo.co.jp/jp/auction/s501296120
Might want to confirm VIN before proceeding further with that one.
Thanks @sin-, i'm having this one looked at.
^^ So the car at Garage Yoshida turned out to be the exact same car that had been auctioned a week earlier.
I didn't bother to have it inspected further as I knew its condition at the auction and wasn't keen on it. For reference the asking price for the car (which I assume had been repaired) was 3.5million Yen.
@sin-, appreciate your help.
I can explain that one, the Auction listed the actual kms travelled as it had a changeover dash cluster. The Garage Yoshida listed the kms on the odometer only.
18 hours ago, dyl33 said:
Where were you when user livewire had his LM for sale, it was beautiful. Good luck with your search!
Yeah, that was my bad... I hadn't quite made up my mind/got my life in order at that point. I'm sorted now.
I have one lined up, I just have to organise a couple of things. Once I have it locked down, i'll be sharing more details.
  • Like 1
  • 3 weeks later...
@sin-, thanks for letting me know. I actually have just purchased one from a SAU member.
I am just working through some details (minor repairs) and shipping, then i will be letting everyone know what I have done!
  • Like 1
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
