Wanted to buy: R33 GTR LM Limited
Currently I have engaged an importer in the hopes of turning up an R33 GTR LM at the Japanese auctions.
Ideally the car will have: 100k or less kms. Prefer original condition, however I would still be interested in hearing from you if you have a modified car.
I'm based in Melbourne, but I would consider any car currently in Australia.
https://www.sau.com.au/forums/topic/465804-wtb-r33-gtr-lm-limited/
Thanks for the link @I gotta R34gtr v-spec, I am having someone (who knows a little more than I) investigate it for me.
If anyone else turns up any other GTR LM Limited's I would still be keen to hear from you. :)
  • 4 weeks later...
  • 3 weeks later...
Quote
This is not important. If anyone turns up an LM in Japan please let me know, i'm searching myself, but others may find things I miss. I have someone in Japan who is willing to look at these for me so all cars are applicable to my search.
@sin-, that's great to hear. Do you have any further details you can give me? A link or where the car is going to auction or it's current location?
Any info would be greatly appreciated.
@sin-, thanks for the tip off. I have asked my contact in Japan to check it out. Funnily enough he said he already had the paperwork and sent it straight through.
  • Like 1
On 9/13/2016 at 9:59 AM, sin- said:
One coming through auction this week 139k 3.5
Took a very long hard look at this car. Apparently had a lot of interest on the day.
The car itself looked good from the outside, but the underside had a coating of surface rust (not a huge) problem, there were quite a few clamps, connectors and other bits and pieces that would have needed replacing.
The real issue was a whole lot of rust surrounding the passenger side suspension upright. The way it was currently it couldn't have been complied before the repairs. Based on suspected work that was needed, I ended up bidding for it with a limit of 2m yen, the car ended up being sold for approx 2.5m yen.
  • Like 1
On 9/17/2016 at 4:14 PM, sin- said:
http://page14.auctions.yahoo.co.jp/jp/auction/s501296120
Might want to confirm VIN before proceeding further with that one.
Thanks @sin-, i'm having this one looked at.
^^ So the car at Garage Yoshida turned out to be the exact same car that had been auctioned a week earlier.
I didn't bother to have it inspected further as I knew its condition at the auction and wasn't keen on it. For reference the asking price for the car (which I assume had been repaired) was 3.5million Yen.
@sin-, appreciate your help.
I can explain that one, the Auction listed the actual kms travelled as it had a changeover dash cluster. The Garage Yoshida listed the kms on the odometer only.
18 hours ago, dyl33 said:
Where were you when user livewire had his LM for sale, it was beautiful. Good luck with your search!
Yeah, that was my bad... I hadn't quite made up my mind/got my life in order at that point. I'm sorted now.
I have one lined up, I just have to organise a couple of things. Once I have it locked down, i'll be sharing more details.
  • Like 1
  • 3 weeks later...
@sin-, thanks for letting me know. I actually have just purchased one from a SAU member.
I am just working through some details (minor repairs) and shipping, then i will be letting everyone know what I have done!
  • Like 1
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
