Hi everyone, been a while since I posted last. I'm looking, preferably, for an OEM 2007 set of projector headlights for my 2005 Skyline 350GT. Failing that can someone point me in the right direction where I can purchase some quality aftermarket headlights. Perhaps someone has got a set for sale??
Would really appreciate your input and help in this matter.
Thanks in advance.
https://www.sau.com.au/forums/topic/465967-projector-headlights/
have done the research a few years back when i had a v35, oem will set you back about $2500+ or aftermarket from ebay about $500-700 and quality is not that good, basically you get what u pay and make sure you buy RHD specific from ebay as many are LHD specific Infiniti USA parts.
Thanks for the reply buddy. I'm not too keen ordering a set from eBay to be honest. I have a chance of obtaining an OEM set 2007 from America but they are all LHD over there. Do you know if the projectors can be pointed to LHD? You would think so given they are made at the same factory in Japan??
What about this company called Mars Sports in Aussie, ca anyone vouch for the headlights they sell? I saw these which look OK - http://www.ebay.co.uk/itm/CCFL-Angel-Eyes-LED-DRL-Head-Lights-for-NISSAN-INFINITI-G35-V35-350GT-Skyline-2D/171267512522?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37430%26meid%3Dc89a81dd056e47cbac70090dbf8e90ef%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D131139343838
Those Mars ones are halogen H7 projectors. Do you have factory HID? Better off with these, as they take the D2R bulb.
http://www.ebay.com.au/itm/LED-DRL-Angel-Eyes-Projector-Head-Lights-NISSAN-INFINITI-G35-V35-350GT-Coupe-2D-/222049768243
I have no idea how the output of those are, they could be just as bad as H7 projectors. Sticking a PnP HID kit into the halogen won't give you a good beam.
Projectors and reflectors are LHD or RHD specific, you can't buy a LHD projector and 'turn it into' a RHD.  It isn't a matter of 'pointing', it is the light pattern which is different..  And definitely don't put HIDs into projectors/reflectors made for halogens!!
Edited by sonicii
Sorry man I don't have a V35. I haven't seen any output shots besides the one:
As you can see, rubbish lol. There is an old thread of people buying that second style you posted (Google "v35 projector headlights", the first SAU result), no output shots though. They seem very expensive to buy and retrofit, so I'd either retrofit the stockers or find a second hand projector set for cheap and open those up.
HID projector should give you something like this (FX-R untuned, unaligned, heaps of foreground):
Or get OEM ones: http://page21.auctions.yahoo.co.jp/jp/auction/j395434936
I had some from the States and had to just dip them a little lower then normal. But you loose light on the left side because of the pattern, makes it harder to see for e.g someone walking on a foot path.
Had them for over 5 years
to bum it just in case if anyone needs like a brand new right headlight from V35 2001 excellent condition
http://www.gumtree.com.au/s-ad/woodcroft/auto-body-parts/nissan-jdm-skyline-v35-4dr-right-hid-headlight-for-sale/1085528972
Or open them up and install some RHD HID projectors ;)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
