F40/50 Brembo Mounts for 340mm rotors / Garrett or Trust turbo that has a 4" inlet
Perfect for any EFR, Precision, Garrett or Trust turbo that has a 4" inlet.  Even better if you run MAP as it means you are sure to get plenty of air into the turbo with little power loss due to less surface area of inlet filters.
Was to be used with my T67 but sold my Greddy setup
$180 plus delivery. Located in Melb
Also found these in the bottom of a box and forgot I had them.  I run 343mm rotors rather than the 340mm these were intended for when used with the Biot 340 rotor and Brembo F40/F50 caliper.
About the biggest rotor / caliper arrangement you can get under most 17" wheels ( I run TE37s with no clearance problems)
There are several cheap Brembo F40/F50 setups for sale on SAU at the moment so will help you get a good setup for reasonable dollars
Off this kit
http://www.biot.co.jp/products/biot/caliper/f50-4pot/
 http://www.biot.co.jp/products/biot/caliper/f50-4pot/brembo-f50-4pot-340/
http://www.biot.co.jp/products/biot/rotor/front/
Asking $300 delivered for them
Ther ppls posts on suitable calipers being for sale
  • 3 weeks later...
 Share
    • Hey all. Had a bit of a scare today with my R34 GTT when i flicked on the tail/parker lights, and  some wiring started going up in smoke under the dash. The fuse didnt blow, it just melted the casing of the fuse so must have been a crap fuse? Previous owner did alot of wiring, some of which is quite sub par and the fuse that melted was definitely newer than the other ones that were in the fuse box, but didnt seem that he touched the wires that mainly got melted. Anyway may need a small section of a new loom, is there lots of similarities between the turbo and non turbo looms especially for under the dash stuff? The wired that got friend go into a 6 pin relay under the dash. The non turbo ones are less than half the price here from a wrecker and all i would need it the section that got fried and any other wires that are affected.  Thanks in advance
    • Nice, they are pretty common mods in the US.  Have been considering sway bars for my Q50 Hybrid.  Given it is AWD, I don't really have any wheel hop issues on hard launches, so I am not sure the diff brace would help as much as it did for you. I'm surprised the diff brace made any difference to shift feel, since it doesn't impact the auto transmission in any way, if anything I would have expected to feel shifts even more as there is less 'give' in the diff mountings to soak up the shift shock.  Are you sure this one isn't placebo?
    • Calling it a dam will probably have the local government charging him for the water that it captures
    • Duncan just needs to start an epic open pit mine, let it store the excess water for him. Call it a dam and the authorities won't say a word
    • Sure, but you could just pull enough timing out of the map to make it idle at whatever RPM you want. Or close the throttle until it's about to bind to compensate for vacuum leaks.That's kind of why I'm not a fan of this approach, especially if OP isn't experienced at tuning these things.
