Near new conditon stainless steel exhaust. Has been sitting on the shelf collecting dust for a while. Font pipes are 65mm into 80mm exhaust. Was going to keep this for rego purposes before doing custom but bugger it...will worry about a street exhaust if I run into noise issues with my custom twin system.
$450 from the MX front pipes.
Sorry about the pics showing dust and crud. If i need to I will give them a wipe down so that you can see the excellent, low km condition
Well...i needed to clean them up to post them so gave them a quick hose. As can be seen they are in good nic...if you are really anal a light polish will have them looking like new
Happy to post
  • 4 weeks later...
  • 1 month later...
Alcon 6 Pot Caliper and Rotors
I have held on to these calipers and rotors for years with a plan of putting them on whatever I bought next, an R31 coupe or R32 GTR. But still dont have the space for a 4th car and reality has set in that I have to continue to part with what I think is cool stuff I have collected over the years for my cars.
I dont intend to run 18s on my my GTSt and it has a good 4 pot Stoptech 343mm setup for 17s and my Cossie already has 378mm 6 pot APs so these have no place to go except a 4th car which isn't happening anytime soon.:(
So, these are similar to the common Alcon Mono6 that many people run on 365x32mm rotor. However these were an Alcon Jaguar caliper that ran 410x35mm rotors on what I believe was their GT4 cars run by Prodrive. So simply put the std Mono6 can only take a 32mm rotor and doesnt have the curvature to go much over 365mm. These take a 35mm rotor and can take any common R35 GTR rotor  diameter.
These calipers are used, but like new. They did one event and the car ended up through the kitty litter so the caliper got a few nics and bumps as rocks bounced around between rim and brakes. They have been freshly coated in silver by HPC and never ran on a car by me. I slapped a vinyl Alcon sticker on the caliper for the pics, but my intetion was to stencil NISSAN on the caliper, but thankfully havent done it to date and guess if I had doen so it would have limited their appeal for this sale. SO you are free to stick the Alcon stickers on them, paint Alcon on them or paint whatever you like
But has evidenced by the condition of the pistons you can see they are  as new.
Rather than the 410mm Jag rotors I have a set of R35 GTR rotors measuring 380x35mm. They re freshly machined and still in spec but wont have another machine in them
The calipers and rotors come with new DS2500 pads, but no brake lines or mounts.
Asking $2200 for them for calipers, pads and rotors.
  • Like 1
Will take $2,000 for the Alcons and rotors
ex HRT Momo seat
EX Holden Racing Team (HRT) seat out of Jason Bright's 2002 car for ride days.
I ran this seat in my track car for a few years and one weekend at Phillip Island Jason Bright was good enough to sign the seat for me
The seat is a Carbon Kevlar Momo race seat. Back in the day it was a $4,500 seat and about the best strength-weight proposituon you could buy. The left hand side head restraint was trimmed to suit the HRT roll cage ( see pics)
The past number of years i have kept the seat for my simulator setup but just don't have the space for it anymore so parting with my part of HRT history
Also  have rear std R33 GTR upper and lower suspension arms for $50 each (traction, camber and LCA)
Also have R32 rear end bits for $50 each, inc LCA and hubs
Also found these in the bottom of a box and forgot I had them.  I run 343mm rotors rather than the 340mm these were intended for when used with the Biot 340 rotor and Brembo F40/F50 caliper.
About the biggest rotor / caliper arrangement you can get under most 17" wheels ( I run TE37s with no clearance problems)
There are several cheap Brembo F40/F50 setups for sale on SAU at the moment so will help you get a good setup for reasonable dollars
Off this kit
http://www.biot.co.jp/products/biot/caliper/f50-4pot/
 http://www.biot.co.jp/products/biot/caliper/f50-4pot/brembo-f50-4pot-340/
http://www.biot.co.jp/products/biot/rotor/front/
Asking $200 delivered for them
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
As per above....BUMPY:  Will take $2,000 for the Alcons and rotors
rotors.
ex HRT Momo seat
  • 3 months later...
    • Not sure what you mean by electronic speedo drive.  Speedo reads fine up to 180 yes.
    • For anyone interested, this is my old graph from 2021, but I've plotted the previous setup curve onto it with a black pen. old setup was: pon cams, oem itbs and plenum, HPI manifold, hks 2835 pro S .87ar rear, Turbosmart actuator, 3" turbo back no res. or cat., greddy spec M fmic, nismo 740cc inj, walbro in tank 460, splitfires, 4" intake pipe, Apexi pod, e85, eboost2, power Fc. I love that the new setup has much larger turbo spec with the HTA3076 1.01ar Ts rear, and literally everything is bigger, but far higher quality and result is it's FAR more responsive in paper.
    • This makes a lot of sense! I just had that realisation a few minutes ago and wrote it above haha. This is a good new discovery. "Sanding the side of the hill" perfect way to put it.   😂 😂
    • This is probably what's happened to me. I'll put filler again on my repairs and use the long block and let you know how I go. Fingers crossed it's my last batch of filler lol. I can see that happening where my block dipped at certain points because it didn't cover all the high spots at the same time if that makes sense. I'm just trying to visualise the fact that with the large sanding block I will be sanding far away from the central dent area and whether that will cause issues or whether that's going to fether out my repairs better.
