Hello,
Up for sale is my 1998 R34 GT-t. 133,111km. I bought this car a couple years back
and am the second owner. Vehicle was only driven on weekends.
Serviced every 5,000km
Vehicle drives well and makes good power. Last tune made 300rwkw and
is tuned by one of the best Microtech tuners around.
The fuel pump and reg are under 5,000km old. Basically new
Only reason for selling is I need a more family orientated vehicle
and don't have the time anymore.
Vehicle is manual
Greddy Intake Plenum
Greddy Type R BOV
Greddy Profec B-spec II boost controller
ID 1000cc injectors
Proflow 1L catchcan
Q45 throttlebody
Plazmaman fuel rail
Tomei Type L FPR
Koyorad radiator
Walbro 460lph e85 fuel pump
Fuel pump hard wire mod
Brae exhaust manifold
Splitfire coilpacks
Nitto clear timing cover
HKS GT3240 0.7 A/R
HKS Adjustable Cam gears
HKS Fine Tune T-belt
HKS 272 degree 8.7 Lift intake cam
HKS 264 degree 8.7 Lift exhaust cam
HKS Power Rocker Covers/ Valley Cover
HKS Oil Cap
HKS Special Racing Wastegate
Kakimoto exhaust tip
3 inch Mandrel bend straight exhaust
Hi-flow cat
Blitz SUS Power air filter
BC V1 Coilovers 8kg/mm front 6kg/mm rear
Work Emotion XD9 18x9+20 18x10+18
Relocated battery to boot
Exedy heavy duty clutch
Slotted/cross drilled rotors
EBC green brake pads (no brake dust!)
Microtech lt16c ecu + hand controller tuned by Anthony Rodriguez @ Maztech
Veilside gearknob
Contact Daniel 0466 577 808 prefer sms during work hours
$17000 ono
https://www.sau.com.au/forums/topic/466248-sold-fs-1998-r34-skyline-gt-t/
Hey mate, boot does look funny there. Had a look this morning. Looked ok. Will post up some more pics in better lighting. No existing damage on vehicle. Just a small dent lhr from previous owner. Paint wise theres chips around the guards possibly from previous owner rolling guards. But overall in decent nick. There is a slight knock from rhf castor bush but willing to fix it for right buyer. Sorry shouldve spent more time on ad. Any questions feel free to ask. Cheers
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
