So I've had my R33 for a few months now and I've recently been having boost control issues. I have Greddy profec B Spec II and its acting very strangely. It drives fine and holds boost until it hits peak boost (14psi) then it will no longer make any boost. The display says it's making around 1psi. But then after leaving it for a while it will work fine again, rinse and repeat. Is it the solenoid sticking open? Any help would be great.
Cheers
https://www.sau.com.au/forums/topic/466339-boost-control-issue/
Well if it works fine with the boost controller unpowered then the issue definitely lies there. The thing is, if it's switched off, the lowest the boost can go is wastegate spring pressure and i would expect that to be between 5-7 psi. You said when it plays up your only getting 1 psi. Since you have an aftermarket split dump, i would definitely check the flapper opens and closes smoothly and doesn't get caught open. Some of the split dumps have a reputation for causing this. Wont take long to check and rule it out as a possibility if it's all good. Cheers.
You're going to have to determine why it's sticky. Most probably it is fouling the inside edge of the dump pipe. You will have to take the dump off to take a look and either dremel it for clearance or replace it with a bell mouth dump. The other possibility is the flapper mechanism itself is faulty and sliding in and out. Pull the dump, diagnose and then take action. Cheers.
No probs. You could also try spraying some wd40 or similar on the shaft of the flapper and open and close it quite a few times and see if that frees it up before you go pulling shit off. I use to have a turbo on an old car of mine that had a sticky gate and doing that would remedy it for a few months. Give it a shot, can't hurt. Good luck
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
