Hey guy another thread about gear oil
Every post i read turned into everyone saying each other is wrong with what oil to put in.
So it doesn't go into gear when cold unless i fight it
And it rarely crunches gear.
So reading the post everyone says use the following:
-Vmx-80
-Syntrans (i can only find syntrax?)
-redline shockproof (blue??)
Can i get a definitive answer please?
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/
Redline shockproof is somewhat of a bandaid solution to a gearbox that has sufficiently unhealthy synchros that they pretty much don't work.  Not the best solution, but compared to a complete rebuild, sometimes the best one available.  I used it in my RB25DET box after the transplant when it would not select any gear at all with the engine running (with conventional oil).  Instantly better.  Has been in there for years now, even though it has a reputation for not being the best thing to run long term.
Other gearbox oils are just gearbox oils.  Some a bit better than others.  Some offer the same rescue service that shockproof offers.  If your box refuses to engage gears when cold, I suspect your first port of call would be to try the best conventional oil and see if it helps, then be prepared to try the smurfs' blood.
  • Like 1
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768212
3 hours ago, Jonnoo said:
Syntrax $30p/L
Vmx-80&vmx-m $38 p/4L
Is syntrax really worth the money extra
Seems a small investment. What do you think you have in your box now that is different from the cheaper oil? I think you'll find Redline Shockproof is not cheap either.
  • Like 1
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768481
It wasn't about cheeping out, it was more about noticeable differences between the 'common oils' before i went with the redline. :)
Anyway its all done, i used syntrans
easy job, hardest part was getting the filler plug off.
Drained i recon just over 1.5 ltrs
Filthy oil had a bit of sludge
No big chunks of metal on the magnet
Filled about 2.4-2.5 L
Hopefully shes all good! If not its redline time! :)57b931782409e_ImageUploadedBySAUCommunit
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768483
The 2 bottles above is how much came out
I used those 2 plus half a third, but i also spilt some.
No idea where a liter would have disappeared to tho
Gear changes do feel smoother
No abnormal crunches (not that there ever was) but definitely smoother...
I wont know for sure until tomorrow morning.
I think the clutch is disengaging properly, it doesn't roll when on a flat surface, next job is to bleed the clutch, never know when it was last done.
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768493
2 hours ago, Jonnoo said:
I used syntrans
I know. I recommended Syntrax or Motul Gear but never mind. Do you in fact have any clutch pedal free play?
Anyway you may be right about the box. An RB20 box won't stand too much caning.
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768966
Unfortunately they only had 1L in stock! I did try for the syntrax though.
Not really free pay but if i rev the car the peddle goes soft i can feel it sort of go lower if my foots resting on it, if that makes sense?!?
Yeah behind the 25 i don't think itll have much left even if it was fine
https://www.sau.com.au/forums/topic/466379-rb20-gearbox/#findComment-7768970
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
