I've got the Acer XB1 Predator it's mad, 165hz and an IPS panel it's the best monitor :D
https://www.pccasegear.com/products/34212/acer-predator-xb271hu-27in-g-sync-ips-144hz-gaming-monitor
managed to get mine for $980 though at scorptec
Edited by UNR33L
5 hours ago, Anfanee said:
The one you linked is a 144hz?
Yeah it's weird how they list it for 144hz yet it's built in with a one button OC / turbo mode that does 165hz :) 165hz + Gsync amazeballs!
5 hours ago, GH05T said:
Yeah im not about to spend that in a monitor
$500ish is plenty i think
At least get a gsync monitor like Anfanee linked, even if you have to lower the cost you spend on motherboard or another component (noticed you have listed a $300 motherboard) better off having a good monitor and average $150 or so motherboard IMO
Edited by UNR33L
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
