Aftermarket temp gauge issues potentially?
Hi All,
I've noticed some issues with my R33 GTST as of late. I was driving up the blue mountains the other day and noticed my temp slowly rising on my aftermarket temperature gauge but the dash gauge stayed in its normal position.
A few days later I was driving uphill and noticed the same issue again, temp was rising slowly to 90+ (which it never normally does). I had a passenger get my laptop out and check the temperature that was showing on my Haltech and it was sitting between 79 - 82 degrees despite the aftermarket gauge rising.
It's worth mentioning that when I stop (at a set of lights etc) the temp goes back to somewhat normal.
I'm really not sure what is causing this but as a just-in-case I ordered three new sensors, ECU temp, Dash temp and aftermarket temp. Has anyone else had this happen to them before? The only two logical things I could think of were there is an airlock that is only affecting the aftermarket gauge based on its position or that the aftermarket gauge sensor is borked.
This is the hose I have the sensor in for my aftermarket gauge
http://www.gktech.com/index.php/r33-silicone-radiator-hose-with-water-temp-fitting.html
Any help would be appreciated
Just now, Dose Pipe Sutututu said:
sounds like an air pocket in the hose... can you get the sensor down deeper so it's touching the flow of the coolant?
The sensor itself is on the underside of the hose so it seems pretty well submerged in the coolant probably halfway in the hose. I'll check if I have a pic on my build thread
8 minutes ago, jmknights93 said:
I'd offer you my gauge to test with but my car may be sold this weekend :(
All good bro, thanks anyway - I'm going to bleed the system anyway this arvo before I leave work haha.
Thanks
Think it's all sorted, the gauge is no longer being erratic - I noticed last night when I turn the lights off the gauge would drop 10+ degrees -_-
Changed all sensors, bled the cooling system and redid some of the wiring again.
Thanks for the input Johnny and Josh
If it was just this that would be normal. ^^^
The stock gauge is programmed to stay in the normal zone until it is really getting hot so that people don't get excited about minor fluctuations. However the fact that the ecu sensor is also staying in the normal zone does point to the aftermarket gauge being the odd man out.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
