R32 GTR Fuse Question
Hello folks, would you know what these two fuses do, "electronic parts" and "transmission control?"
My R32 GTR arrived a year and half ago with those 2 fuses missing.  I have always driven my car without them and I just now notice they are missing.  Have I damaged my car in anyway driving without them?
Thanks in advance for your inputs!
https://www.sau.com.au/forums/topic/467099-r32-gtr-fuse-question/
Fuse #2 (Electronic parts) appears to control only the automatic spoiler and it's computer and switches
Fuse #3 (Transmission control) looks after the auto trans gear selector and computer
If neither of these are working, and should be, then put a fuse in.....otherwise everything is fine :) They use the same fuse box for all 32s with lots of different engines, transmissions, features
Thanks a ton for the information, I got really worried for a while, phew!
I don't believe I have active aero's, so Fuse #2 is likely unused.  And I have a standard R32 GTR, so Fuse #3 should be unused.  Mystery solved, I can go driving again! :)
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
