New (frustrated!) Skyline owner
Greets,
First time Skyline owner (R32 GTS-T) looking for an online community to lean on when need. I've got some issues to sort out before winter sets in, but so far I am excited about my first Skyline.
Mike
  • Like 1
https://www.sau.com.au/forums/topic/467184-new-frustrated-skyline-owner/
Hello and welcome!
Thank you!
howdy, you have come to the right place. most of your questions will be answerable by searches and if that dosnt do it get asking.
is that your car pictured?
Thank you for the welcome, that is my car pictured.
Welcome to SAU!
:welcome:
Thanks!
10 hours ago, V28VX37 said:
Welcome! ...but why frustrated?
I can now say Formerly Frustrated, ha! Over the weekend my GTS-T drove terribly- no boost, breaking up under load unless I babied the throttle.  I got in it yesterday morning to drive it to work so we could diagnose the issue (thankfully I work in a VW/Audi tuning shop and have techs that are enthused about Japanese imports), and after a couple coughs and sputters it's back to driving as it should, although the boost gauge on the dash is no not working.  2 steps forward, 1 step back, right?
My initial plans for the car is maintenance, maintenance, maintenance- new tires, alignment, fresh oil, and new coil packs.
Edited by planrforrobert
Also, can you confirm that what's written on this sticker would indicate that the timing belt was replaced at 104300km and should be replaced again on/around December 19, 2016?
I'd read the date on that sticker as the 16th December 2019, but this wiki page - https://en.wikipedia.org/wiki/Date_and_time_notation_in_Japan - suggests that your interpretation is correct - 19th December 2016. I'd be inclined to go by the kms travelled, but if the US is like Oz the reading on the odometer may be incorrect.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
