New (frustrated!) Skyline owner
Greets,
First time Skyline owner (R32 GTS-T) looking for an online community to lean on when need. I've got some issues to sort out before winter sets in, but so far I am excited about my first Skyline.
Mike
  • Like 1
https://www.sau.com.au/forums/topic/467184-new-frustrated-skyline-owner/
Hello and welcome!
Thank you!
howdy, you have come to the right place. most of your questions will be answerable by searches and if that dosnt do it get asking.
is that your car pictured?
Thank you for the welcome, that is my car pictured.
Welcome to SAU!
:welcome:
Thanks!
10 hours ago, V28VX37 said:
Welcome! ...but why frustrated?
I can now say Formerly Frustrated, ha! Over the weekend my GTS-T drove terribly- no boost, breaking up under load unless I babied the throttle.  I got in it yesterday morning to drive it to work so we could diagnose the issue (thankfully I work in a VW/Audi tuning shop and have techs that are enthused about Japanese imports), and after a couple coughs and sputters it's back to driving as it should, although the boost gauge on the dash is no not working.  2 steps forward, 1 step back, right?
My initial plans for the car is maintenance, maintenance, maintenance- new tires, alignment, fresh oil, and new coil packs.
Edited by planrforrobert
Also, can you confirm that what's written on this sticker would indicate that the timing belt was replaced at 104300km and should be replaced again on/around December 19, 2016?
I'd read the date on that sticker as the 16th December 2019, but this wiki page - https://en.wikipedia.org/wiki/Date_and_time_notation_in_Japan - suggests that your interpretation is correct - 19th December 2016. I'd be inclined to go by the kms travelled, but if the US is like Oz the reading on the odometer may be incorrect.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
