R33 GTS-T Aircon Problems
So just in time for a north queensland summer my aircon on my 1997 R33 GTS-T has decided to only blow hot air. Before this it would ONLY blow cold air when set to 18 degrees and turn to full heater when set to 19 or above, i believe this is a problem with the internal temp sensor or the sun load sensor (i ran the diagnostic test on the head unit) and have found the they may just need cleaning. However now there is absolutely no cold air at all and no discernible load put on the engine when the A/C is switched on as it always used to. I found the problem to possibly be that all the gas had leaked out of the compressor side hose, which filled the activation wire with oil/water. Although, as i am a cheap uni student, i was hoping it wasn't in need of a regassing so i decided to check the plug itself and found that even when the A/C signal and relay sensors are on (shown by the consult port from the ecu) the wire running into the compressor was only registering 0.3Volts (which is what it was showing even when off so i assume it is a background noise voltage or something) so im unsure whether it should be a positive voltage or if it should be earthed . I also know that somewhere there will be a low pressure sensor but as i could not see any more wires running to the compressor i assumed this would all be self contained.
So my questions are:
-Should there be a 12v signal or earth applied to the compressor to engage the clutch
-is there any other wires that i have not seen running into the compressor
-if i manually send a 12v/earth signal to the compressor will i cause any issues (just to check if the clutch is engaging and the problem is i am just out of gas)
and then less importantly
-are the internal temp sensors standardised as i can't seem to find a replacement
and finally does anyone actually have a sun load sensor (from all i've seen in forums everyone seems to get this error)
Thanks in advance
Joe
Edited by joseph0205
https://www.sau.com.au/forums/topic/467212-r33-gts-t-aircon-problems/
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
