1989 R32 GTS
Selling my P plate legal nissan skyline r32 gts auto due to no funds, space and one too many cars.
Car is stock except for exhaust, head unit and speakers.
Engine runs perfect but gearbox gets stuck in 1st and 2nd at high rpm before changing gears.
The idle needs to be looked at, sometimes on the low side when cold.
Heater core and coolant has been flush and changed.
Needs a new coolant reservoir tank.
Engine oil and air filter been changed recently.
Aircon compressor seized so would need new one.
Horns not working but suspect due to relay.
Some interior lights in the car are not working.
Cars not perfect as you can see in pictures but that's expected of it's age.
There's dints, bubbles and rust. Just needs some tlc. It needs abit of work but can definitely be registered.
Car can be driven, just minor issues to be fixed.
I have been as honest and truthful as i can be with describing the car.
Selling with no rwc no rego. $4500 neg.
Located S.E. Melbourne.
Prefer inbox or message/text. 0402697000
https://www.sau.com.au/forums/topic/467355-1989-r32-gts/
  • 4 weeks later...
  • 5 weeks later...
  • 2 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
