VCT Problem
Hi guys,
I have an issue with power loss at 5.5k rpm onwards, after much troubleshooting im quite certain fault lies at the vct.
I disconnected the plug, went for a drive and no changes. Same power at low end...and same power loss at high. I removed solenoid to see if actuator is working and it is. ticks and closes when fed direct 12v.
Power fc is sending the signal. So its not the ecu.
Now when i put the solenoid back into the head. wired direct 12v into it... it ticks and can feel the actuator moving(vibrates)  however no change in idle whatsoever. From what i understand there was suppose to be a noticeable change in idle when the actuator closes. nothing happens.
Would this point to the vct cam pulley mechanism being stuck/jammed?
https://www.sau.com.au/forums/topic/467779-vct-problem/
If it is the vct, it would be stuck in the on position. That would explain the power loss after 5.5k, that's around the switch off point. I'm not really sure how you can trouble shoot it. I have seen second hand vct gears for sale on eBay for cheap as if it comes to that. Good luck.
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792334
yea mate, im somewhat confident its the issue, but before i go ahead and replace the cam gear, just wanna know if there was anyway i can confirm its stuck inside or something. so that at least ill understand what happened. or what caused it and such. im worried that i replace it and problem lies elsewhere kind of thing. just wanna make sure i get it done right.
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792336
this is what ive gathered so far.
On 27/02/2012 at 6:06 AM, The Dan said:
When I said move it by hand I didn't mean you could grab it with your fingers and turn it lol.
Cam gear on, belt on.........turn the bolt in the centre that holds it on the cam until it's tight. When you turn it further to tension the bolt, the camshaft will turn but the outer gear part will stay still.
You are looking for the wrong problem. The gear will be fine on both
taken from
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792346
as that post said, to rotate the cam manually.. i was wondering, if it were to be stuck in advanced.. would it be safe to rotate it anti clockwise (retard) to get it unstuck ? logically im thinking it should be ok.. but dont want wanna be a smartass thought ill check first,
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792352
not much help eh .. hahah its ok ..ill just keep this post updated in case anyone is facing the same issue.
today i got the cam covers off... tried moving the intake manifold but the main bolt(after removing the vct cover plate with spring loaded in) and it was not moving. it was stuck. tomorrow ill be removing the timing belt off, and pull the intake pulley out and have a look.
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792578
pulled of the intake pulley, noticed in the vct cam gear, small amount of debris, oil inside the gear felt rough. suspect this could have gotten the pulley stuck. got another pulley from a friend on its way. hope this fixes the problem.
  • Like 1
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7792856
  • 1 month later...
Did you end up working this one out mate?
  • Like 1
https://www.sau.com.au/forums/topic/467779-vct-problem/#findComment-7804104
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
