Yellow Jackets Ignitor Module and resistance test results
Hi All,
Keeping this short-ish, I'm chasing a misfire when on boost.
Replaced the plugs.  Interesting found BCPR7ES-11 in there from the last mechanic, no big deal.  Anyhow, replaced with BCPR6ES-11.
The air box has been out/in recently, Will check it's gone back on properly tomorrow with some light.  Maybe it is un-metered air.  I hope it's not the AFMs, been through 4 sets...
But, I have a feeling it is the 20+ year old coil packs and/or ignitor module.  Found this (awesome!) video on how to test the ignitor module, again I'll give it a crack tomorrow.
So, here are a few questions:
- Anyone tested their ignitor module like this before and care to share results?  Think, a yard stick besides what is in the video.
- Anyone using Yellow Jackets ignitor modules?  Keen on comments for the R32/33 GTR unit, but I'll take anything.  What I've noticed about their coil packs, asides from amazing service (Performance Wise) replacing failed units, it is hit and miss.  When it is hit, they are good.  I can't find anything about the ignitor packs to make my mind up.
- Comments on refurb OEM units?  See eBay link
Pricing up the ignitor pack.  SuperCheap - $1600+ (OMG!).  Kudos - about $600.  Refurb - $400.  Yellow Jackets - $200.
Lastly, I'm a massive lurker here.  Heaps of thanks for the great info here.
Cheers!
The ignitor modules really are just 6 transistors, so it shouldn't be hard to make an aftermarket equivalent OR refurbish an OEM one.  The thing I would avoid though is anything that comes from a source (such as Yellow Jackets) that is known to have a patchy record.  It is just too easy to make these electronic thingos with shit quality Chinese made components when for 30c more you could make them with good quality Chinese made components and for another 50c you could make them with top quality Jap components.
Not sure what happened with the double post... anyhow, here are the results.
Testing as per the above, pins (cylinders) 1 to 6 tested at 500 ohms +/- 10 ohms per pin.  What raised an eye brown, the video tested at 8 Mohms.  The two units are waaayyyy different but who knows which one is right.  It would be good for some more results.
Testing in reverse. each pin read open - sweet.
Here is where things start getting interesting.  Quoting the electronics buff who's multimeters we used, we were testing the "forward junction voltage on the base emitter" - this isn't covered in the above video and honestly, nfi, but it sounds good.   Pins 1 to 5 read 1.2v.  Pin 6 read 0.6v.  Testing across three multimeters and a transistor reader, this was consistent.  Then, all of a sudden, all pins started reading 0.7v.
So, something is wrong here and I ordered a refub unit.
I used a yellow jacket r33 s1 igniter on the rb25 in my old 180sx for 2 years at a bit over 200rwkw getting trashed hard every time it was used never gave me an issue. Still got it in my garage actually
Update.
Went looking for un-metered air, found oil from the K&N panel filter in airbox.  A substantial quantity.  Pulled the airbox, cleaned the AFMs and had the filter on paper towel overnight.  Took it for a drive, it is still missing (more like popping, at a guess it is unburnt fuel) under boost.  Might just replace with a paper filter.
Replaced the plugs with a set of BCPR6ES, no -11, and even better but still missing.
Did a visual inspection of the CAS and timing.  Besides missing a bolt on the bottom of the CAS, it looks out.  Don't have a timing light, so can't do an actual reading.  Could someone chime in?
You can't assume its out because it 'looks out'
Get a timing light and plug lead and check it properly. There is something you have to unplug to check it so the timing doesn't jump around. From memory its the TPS plug
True @89CAL, can't tell the timing without actually checking it.  I just found it odd that it's waaaay off the 20 degree mark... but hey, it's running fine.
I'll need to put a few more KMs on it, but I think the misfire is gone.  Swapped the K&N panel filter with the old filter and all the problems just went away.  Swapped the old filter with a new one and so far so good.
Air, fuel or spark.  Back to basics hey.
Yellow Jackets are junk, dont waste your money.. i dyno engines all day every day and in the short time (5+years) yellow jackets have been around they account for more ignition troubles on the dyno than all the others combined..
  • Like 5
On 12/9/2016 at 7:36 PM, 89CAL said:
I was actually curious about the YJ ignitor. Im not aware of any other after market ignitor?
well based on the quality of the other products they produce why would the ignitor be any different?
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
