Is she running yet ? , I see you got rego plates on it.
was it hard getting blue slip
That plate is there because i had to leave it on the street overnight. (Live in unit block and manager is a w#nker) so not rego yet. Still heaps to fix on it (driveshaft boots, lower ball joints, new hub bolts)
We have been able to locate the issue and will have the locksmith sort it. Appears to be a faulty ICU box (in ignition tunnel).20161210_172720.thumb.jpeg.fcee3b5ca31fb
Can't get over how many speakers there are, and the audio setup in general... seems quite smart.. you can buy a centre speaker from alpine I think that may fit a touch better where the screen was.. I'm guessing it's all more reasonably priced in Japan hence the amount of work that was done [emoji736]
  • Like 1
I have made a harness and will be testing the ICU on Thursday. I have removed the carpet as its not in the best shape and tidying up the audio components as well to find why the food screen is not picking up the video input. . Engine hoses and bolts ahve been vhecked and tightened as there were a few that were loose. Next to get her started. I have located another ignition barrel and key to replace the faulty one along with other items such as carpet, radiator overflow tank, washer bottle and pumps, battery cover, interior bits to replace the speaker panels in roof whrn i tidy up and conceal the audio.
20161213_170410.thumb.jpeg.9bed12d3c997120161213_170324.thumb.jpeg.edfb240bef74620161213_170320.thumb.jpeg.4e12467b6c8e020161213_170316.thumb.jpeg.f08731f0c9e7820161213_170304.thumb.jpeg.f2e03f133d87620161213_170257.thumb.jpeg.7e4c3bc8e4b0520161212_195646.thumb.jpeg.e8b70b2909917
  • Like 1
Been a busy night. Sub enclosure, false floor, amp box , amps & sub removed. Also removed the rear hatch screen and excess wiring not required. Looks alot cleaner now. Plan is to hide everything for a more cleaner look. 20161215_203648.jpeg20161215_204810.jpeg20161215_205753.jpeg20161215_210708.jpeg20161215_210746.jpeg20161215_211830.jpeg20161215_224204.jpeg20161215_225402.jpeg20161215_230940.jpeg20161215_230955.jpeg20161216_001701.jpeg20161216_001715.jpeg20161216_001723.jpeg
  • Like 4
Gee for a bit of bass, I'd be sweating all the time of getting a flat...
At least you could listen to awesome sound while you're waiting for the tow truck.
Run flats ?
Yeah as i need to register this and do a road worthy im planning on putting tge spare back in and putting the amp on the under floor tray like i did my last car. That way i can have both. Picking up a spare gearbox today and will be swapping over the speed sensors as i have a 16 flash Check AT error code (Speed Sensors). Im not sure which one so ill swap out both.
Very productive day today. I have a 16 flash AT error code which relates to the transmission speed sensor. I have sourced a spare gearbox where i have taken the valve body out of and swapped it into the m35. 20161217_133907.thumb.jpeg.4407024403a8e20161217_150943.thumb.jpeg.8c5c588bc42ea20161217_153641.thumb.jpeg.a4161fa52b42b20161217_153651.thumb.jpeg.df8bcb58dc05720161217_174749.thumb.jpeg.874126ff570a220161217_181208.thumb.jpeg.16165b75ad433
  • Like 2
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
