12 minutes ago, GTofuS-T said:
Also, I've been meaning to ask... You're changing turbo due not suitable for skid pan, but did you end up taking it to a circuit to see how it went? I thought that was the main goal?
I think I will be doing more skid pan days than track days coming up next year, the current turbo setup doesn't come on till 4300rpm (which isn't that bad for something potentially making close to 420~430kW). I was hoping to get the same level of boost threshold as my old billet Hypergear ATR43SS2 with this turbo however it doesn't. Also the transient on this turbo is much lazier than the SS2, then again this turbo's turbine side is essentially a GT35 where as the SS2 is a GT30.
My future goal is, early torque and early boost like my old SS2 setup but with about 420kW+, hence I've ordered (still waiting) a GTX3576R Gen 2 with a 1.01 divided rear housing.
  • Like 4
No real update, started car 1st time in 3 weeks. Started first go, still 20 seconds before it builds oil pressure.
Revved it a bit, dosed it a few times. Turned it off, next week will be going to my mate's shop and ripping off the sump and oil pump. Fingers crossed nothing catastrophic and only a cracked housing. Have a new housing to go back on with the existing Spool Import gears.
After that, maybe drop a set then back home to remove the turbo setup.
  • Like 1
  • 3 weeks later...
Happy New Year!
So some updates (no photos though, broke my "waterproof" phone when I jumped into a pool).
Removed sump, oil pump, oil pump housing to find that the innards were all scored and pitted as though something was ingested, however the sump and pick up appeared to be spotless.
Billet gears inside all damaged and just for a sanity check, decided to measure the tolerance between the crank snout (made by Spool Imports) and the Billet Oil pump gears and discovered a whooping 0.22mm tolerance each direction (not sure intentional). Have contacted Spool but they're off till the 14th of Jan.
Also got a call from Sparesbox yesterday and they're now (after 4 weeks) unable to supply me with the GTX3576R Gen 2, instead they've offered a GTX3582R Gen 2 instead, beggars can't be choosers so I said yes.
  • Like 2
Hoist life, seems like natural habitat for this sietbok.
A bit of skills involved but managed to remove sump, and oil pump with motor in the car ?
And yeah here's what billet gears looked like after I started having oil start up issues.
Sump, filter, pickup all clean. So must have been from the start I assume.
  • Like 2
  • Sad 1
23 minutes ago, ActionDan said:
Damn 0_0
The regret of not stripping the car and parting it when the original exploded was a big mistake and regret. I could be in a F30 335i at this moment talking about Stage 1/2/3 tunes using my phone and getting the latest cold air intake and yet lap a comfortable 1m8s around Wakefield with some decent tyres.
Oh wells, at least I have the Tiguan which ALWAYS delivers
  • Like 1
But when you get the better turbski and this thing delivers you'll have maybe 500 f**king kw to blast around with.
This is a track car, dont compare it to a daily with some bolt ons.
9 hours ago, ActionDan said:
What?!
I would never sell my tools lol
Only tools you need for an European car are a mobile, flash cable, and a good credit card.
  • Like 1
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
