RB26 Boost Valve Solenoid
Hey all,
Just a couple of questions about the stock boost/pressure control solenoid on the RB26.
Am I correct in saying that the green tube, facing the front of the car, is the inlet tube (to the solenoid) and the blue tube, facing the engine, is the outlet tube (from the solenoid)?
If I block either of these tubes completely with a ball bearing will I run true wastegate pressure on the turbos and eliminate any pressure being bled and re-directed back through the system?
Cheers, Foszy.
https://www.sau.com.au/forums/topic/468109-rb26-boost-valve-solenoid/
Think about what happens when you block either one of these tubes. What is that going to do?
You will stop any boost pressure reaching the actuator
What do you think happens if there is no boost pressure at the actuator?
If you want to run the wastegate spring setting for boost, all you have to do is run a boost line directly through it (bypass the solenoid)
If I block either tube directly at, or close to the solenoid itself, how does it block pressure from reaching the actuators? From what I gathered a nipple from under the rear of the intake plenum feeds the actuators boost pressure and the solenoid is hooked up in this hose system to bleed around 2psi from this "green" set of hoses, through to the "blue" set which is redirected back to a pipe on the second turbo (pre-intake).
If I just connect the two tubes (going into the solenoid) and bypass the solenoid, wouldn't it just continuously bleed the boost pressure back through the second turbo and never allow enough to get to the actuators, and result in infinite boost to be built up?
I was going with the idea of removing the stock boost restrictor allows more pressure to be bled back through the system, so having a smaller restrictor would result in less being bled, and as a result, having it completely blocked would mean wastegate spring pressure would be used?
Edited by Foszy
insert line break
The solenoid completes a circuit. (As per your pic above) If you block either tube it will not act on the actuator. If you join the two tubes at the solenoid (bypassing it) you will run wastegate pressure
Just join the lines where they start to go around the back of the engine
Yea, that's what I thought judging by that diagram, as it just shows the solenoid tubing, but then on the vacuum diagram you can see that the plenum feeds the actuators boost pressure and the solenoid breaks into the tubing and bleeds/redirects some pressure back through the intake of the second/rear turbo (as also shown in the second diagram). If it was like this and I connected the two it would just bleed/redirect everything to pre-turbo.
I coloured the corresponding tubes in another diagram of how it seems it's actually set up, apart from it getting boost source from the compressor housing instead of the intake plenum.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
