R34 25GT-FOUR
Hello everyone, i have been looking up some information on a R34 25GT-FOUR that i might be buying soon, the question i'm trying to find an answer to is the AWD system, is a the same setup as a torque split or is it always in 4wd mode. A few sources have said its always in 4wd mode and others say its 2wd until traction is lost. What makes it more confusing is that it is running a R33 RB26DETT engine with a R32 gearbox.
Thanks
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/
The R34 atessa is always on - supplying 5% to the front until the computer tells it to increase it.. Despite the fact that it has an R32 box (why??) it will not behave like an R32GTR where you can disable the awd by pulling a fuse. If you want 2wd you can drop the front driveshaft or there is there a procedure you can go through which is not simple.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801526
Awesome, thanks. I'm not to sure why it has a R32 gear box, it used to be a RB25DE auto and has been converted to manual, which also brings up another question. At the moment the speedometer is not reading the correct speed and the cluster is still the auto cluster, replacing the cluster with a manual wont fix the speedometer problem? I'm assuming that ill need to get a speedometer corrector installed.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801528
Probably the speedo is wrong because the speed sensor pinion from the gt four wasn't fitted into the R32 gearbox. The gt four has 4.34 diff gears, whereas gtr has 4.11, so you need to use the correct speedo sensor pinion.
I have a R33 gtr gearbox in my R34 gt4 - in fact you can swap an auto 4wd gearbox speedo sensor into the manual box. This is what i did.
In other words, you need the R34 gt four speed sensor, to match your diffs. Note that I'm assuming the car has kept the 4.34 diffs, not swapped to 4.1. Either way, they just have to match.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801538
I have read varied opinions regarding whether the factory electronic sensor from R33/R34 will or won't fit into the R32 box. I haven't tried it. Did some research though, the speedo drive gear on the output shaft is the same, R32 to R33. I think even the rear housing is the same.
Also, correcting myself from above, GT four is factory with 4.363 gearing.
https://www.sau.com.au/forums/topic/468359-r34-25gt-four/#findComment-7801749
  • 1 month later...
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
