C34 rear end clicking at slow speed
Hey guys, having some noise from the rear end of my '99 RS4S with LSD (I think its a 2-way), seems to be happening more but the weather here has got really cold lately (a high of around zero C and a low of minus 5 C) so that might be related.
At slow speed, I'm hearing a clicking/snapping/metallic click noise coming from the rear. Sounds to me like it's rear left, but my wife thinks its rear center/left/right. It is not rhythmic as far as I can tell. ie if I'm going along it doesn't happen at a regular interval. Has been happening a bit lately around 40kph and even 60 kph once or twice. I don't notice any movement or jerks/etc, just the noise. Really want to address it if its something wearing out, etc.
Doesn't seem to be tied to bumps in the road surface, so I don't think its the coilovers but who knows. Sounds really similar to a frontend noise that turned out to be the sway bar link, but it's not as predictable with the rocking of the car like that problem was.
In case its related, theres some vibration in the drivetrain from time to time which could be front end but could be rear end related too.
Cheers!
https://www.sau.com.au/forums/topic/468411-c34-rear-end-clicking-at-slow-speed/
clicking in rear site:www.sau.com.au
Copy and paste that into google.
Honestly it could be anything, arms, driveshafts, diff, etc. You'll most likely have to get out some tools and have a poke around, get a big pry bar and put some pressure on all the pivot points on the arms and see if anything moves.
I had a low speed scuff and a click after installing my new Nismo 1.5-way, turned out to be two unrelated issues:
  • Handbrake setup binding
  • Tail shaft counterweight just touching the mid muffler at certain revs, making a clicking noise
Neither issue was diff related but I was super attuned to all noises from the rear after getting the LSD done :)
Thanks guys. Gonna get under it this weekend and do a visual plus moving things to see if I can reproduce. Definitely happening quite a bit today. Doesn't seems to affect driving.
Good plan. Put the rear on stands and run it in 1st gear & listen carefully next to each wheel, that helped me pinpoint some of the issues.
Sounds good thanks @V28VX37 I'm a little sketchy on running it on stands, but as its 4WD, I would need to have it on stands on all 4 corners? I would love to be able to see the drivetrain running. I have a vibration issue I've been trying to eliminate for a while now and the mechanic has told me to take it to a driveline expert. I'd like to have some knowledge going in.
Yep all four corners up for sure since it's 4WD.
I've made small adaptor blocks out of wood to allow jack stands under the sills, at the standard jacking points. This means that the suspension is fully unloaded when on the stands.
There shouldn't be any issues running your car on stands unless there's enough vibration to cause it to jump off, which is pretty unlikely. As a precaution you could have a mate with one hand on the ignition to shut it down in case anything goes astray.
Thanks @Trex and @V28VX37. Those wood blocks sound like a smart idea.
I might put it into 4wd diagnosis mode (pull the green plug in the kickplate) and do the 5 brake pedal stabs to force the car to run in RWD. Will do that and drive a little so that it's definitely doing it before jacking it up.
  • Like 1
Also do the most basic test - put car in neutral and turn wheel by hand when jacked up. If there's increased resistance at a certain spot across the rotation it could be the hand brake assembly, this was one of the issues with mine.
  • Like 1
Be careful, that won't remove all drive from the front wheels in a C34 (or and R33 or R34 for that matter), if you are going to do this you still need 4 wheels off the ground.
I think you might be better to take it to a competant mechanic, they do this sort of stuff all the time without a ferris bueller's day off type ending
  • Like 2
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
