FS: R34 GTT & GT brake boosters, BM50 & BM44 BMC, DBA T3 310mm rotors, AN10 Hoses, R34/R33 transmission parts [MEL]
Replacing my previous for sale thread with this updated one, here goes.
For sale:
1. R34 GTT brake booster with BM50 master cylinder – $100
2. R34 GT brake booster with BM44 master cylinder – $100
3. DBA T3 4000 310mm rotors x2 for R34 GTT front, worn – $80 for the pair
3. Leaky Driftworks braided oil cooler hoses with crimped AN10 fittings, for spares – $30
4. R34/R33 transmission parts – $80
See below for details. All parts in Melbourne near Essendon, pick up only. PM if interested.
I was going to replace mine with this but my issue was elsewhere.
  • Was sent to me as a working unit but I haven't tested it, you're welcome to inspect in detail
  • The plastic fork collar is cracked on one side (see photos) but this shouldn't affect operation
  • The master cylinder doesn't have BM50 stamped on it, however the outer diameter is the same as the BM50 on my GTT so I trust it's the same unit
This was sent to me by mistake when I was after the GTT booster+master.
  • This is in slightly cleaner condition than the GTT BM50
  • The BM44 BMC outer diameter is slightly smaller than the BM50
3. DBA T3 310mm rotors – $80
  • Rotor are about 2 years and 20,000 old, with several track days on them
  • I believe one of the rotors is slightly warped, it's fine for street use but does vibrate in hard braking (runouts are 0.10mm and 0.04mm)
  • No visible cracks or significant heat stress marks on the surface
  • Rotor thickness 29.1mm (new 30mm, minimum 28mm)
4. Leaky Driftworks braided oil cooler hoses with crimped AN10 fittings, for spares – $30
  • Hose lengths are 115cm and 135cm
  • This is heavy duty braided hose about ~25mm outer diameter
  • The AN10 hose fittings for each hose are 90 degree elbow at one end and a straight one at the other. The fittings need a good clean.
  • Caveat emptor: These hoses leak at the straight end, so you'll need to replace those two crimped hose end fittings. Standard Speedflow etc. AN10 fittings won't do because this hose OD is larger than the Speedflow AN10 hose.
5. R34/R33 transmission parts – $80
RB25DET manual transmission parts:
$50 - R33 Series 2 fuse box to gearbox wiring loom
$40 - R33 GTS-t manual coupe tail shaft rear part
$20 - R34 turbo gearbox clutch fork (pull type)
RB25DET automatic transmission parts:
$25 - R34 GTT auto brake pedal
$40 - R34 GTT auto sedan tail shaft front part
Or $80 for the lot of trans parts.
Notes:
  • All prices ono and all parts in Melbourne near Essendon, pick up only.
  • Only items specifically listed above are available, there are some in the photos that are gone
Keen on the front rotors, just doing some pricing up to freight them to me in Adelaide
Would you be able to pack them and I could organise collection?
Hey man, probably easier to pick up, let's organise by PM :)
  • 3 weeks later...
Following parts still for sale, Melbourne pick up only:
  • 1 month later...
  • 3 weeks later...
  • 7 months later...
Long time bump, following parts still for sale, Melbourne pick up only:
1. R34 GTT brake booster with BM50 master cylinder – $80
2. R34 GT brake booster with BM44 master cylinder – $80
3. Leaky Driftworks braided oil cooler hoses with crimped AN10 fittings, for spares – $20
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
