Hi guy's just wanted to to find out what types of protection systems people are using to protect their pride.
I can think of :
House alarm
House camera's
Car alarm
Wheel clamp
Steering lock
Gps tracker.
So ATM i have Hikvision cameras 4mp got the entire home covered i upgraded one of the camera for up to 70mtrs of night vision down the long driveway got the professional installation of it.
Can view live from anywhere in the world.
Basically if the airport using them its good enough for me. Image is so good i rekon ill see a mouse run from about 35mtrs away.
Home_34_20170112095908919.thumb.jpeg.02d
As for house alarm sensors are in garage too im using bosch.
Now i do i have a car alarm i think its autowatch. Have not played with it much seems to be ok
I thinking of using a steering wheel lock old school should I ... .?
Is anyone using a gps tracker and remote kill switch ?
ive heard of them but very spectacle of it.
Now if it not a daily wheel clamp it ?
Or too much damage for a sexy LMGT1
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/
Damn that's a good quality camera.
Got generic cameras around the house. I disconnect the battery and take the steering wheel off (quick release).
You can also disconnect/remove an AFM/the ECU/kill switch, but if someone wants your car, they'll pull it up onto a flat bed.
Don't clamp the LMGT1s please :P
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7806414
Oh ok remove the steering wheel awesome idea.
I have a Daikei steering wheel boss is that a quick release.?
Thank you yes they are great camera's its actually a bit more then 1080hd
With the kill switch i was thinking like calling the car and it just dies on them then i get gps location and boooom got em.
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7806510
Found this car tracker aussie guy that imports n sells em
Just wanted to know if anyone using it coz apparently he sell them to big companies and most rental car company.
It even features a kill option so positive wire on relay connect to fuel pump or whatever triggered by sms
Only thing i want to find out is how good is the reception ? Using telstra.
And did anyone test the kill switch ?
Product looks promising.
http://www.ebay.com.au/itm/262745785716
1485508299667.thumb.jpg.3cc31cb960dcf3e6
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7807357
Sounds good for the price
The concern I can see just quickly looking at it is that there is no integrated GPS, so Im gatherithing its using multiple mobile phone base stations (normally 2, lucky 3) that triangulate on sim signal to indicate estimated location. This fails in accuracy for a number of reasons when something valuable is at stake, but I guess u can add a gps in the port but then price/value changes
Edited by Watermouse
  • Like 1
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7807360
Found another idea that is super simple and makes it just that little bit harder.
If your car is lucky as mine with its own personal garage.
Switching the power off is great in my mind.
Got the idea coz when i was a kid i used too ride on my bike changing my remote codes and use to open peoples doors haha hope it won't bite me in de ass now !!
1485914449598.thumb.jpeg.65c1d850b46b44e
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7808237
  • 1 month later...
my bad, only have blue tooth range
Oh I've seen them pop up on Facebook a few times i looked into them and found that one brand sync with a wifi network and makes a wifi networking range with other key finders so it has a bigger range downside to this is that 1 has to the wifi connected or Bluetooth 2 needs other finder to make a network for longer range 3 makes drop point location not gps location on demand [emoji20]
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7819403
I recently installed the tracker thats listed above that i got from ebay aussie guy and even call him to get more information before i paid 4 it.
I must say that I'm very happy with the product once i activated my simcard installed the tracker nice and deep ( what a pain is the r33 dash !!! anyway ) connected the 12V+ Ground- and Accessories and log on to my account online very easy must say very accurate too the dam thing know what side my car is sitting in the garage. [emoji12]
Also came with a relay for a fuel cut out by sms will update on how it work well once i get around to it.
https://www.sau.com.au/forums/topic/468757-best-security/#findComment-7819413
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
