Painting S1 C34 Headlights?
So there seem to be plenty of tutorials on painting or cleaning M35 headlights and even some on the S2 C34 headlights.
What I want to know is if anyone has painting their headlights black or some other colour, obviously not the reflector, but the other chrome bits. As I have spiders and some gunk in there and it just looks bad, seeing as i'm cleaning up the car heaps I thought i'd knock it out of the way now.
Thx
https://www.sau.com.au/forums/topic/469155-painting-s1-c34-headlights/
12 minutes ago, niZmO_Man said:
Bake/heat headlight, take apart, prep the surfaces, paint, let it dry overnight, assemble, bake/heat.
Bake the headlight so separate the glass from the rest of the assembly? Do you know how hot/how long? and then I guess bake it again to join the headlight back to the assembly?
Sounds easy enough I guess, do I need to replace the glue or what not that was used to hold the glass to the assembly?
Thanks.
You shouldn't have to replace it, hell it was fine for my R32 headlights (I haven't replaced any butyl in all the lights I've taken apart). I think baking is around 120°C for a few minutes. I use a heat gun these days to soften the glue and avoid messing the oven/melting plastics.
  • Like 1
Seems like its not a simple job lol. But yeah I think i'd rather use a heat gun if that works, I'll have to borrow someones or go buy one lol.
Thanks for your help.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
