Stroker kit sold!
Turbo still available... f**k buying Cadbury halal certified "non easter eggs"  this Easter! Treat yourself to an epic turbo that gives no f**ks about your religion! ?
  • Like 3
Come on guys make an offer on this thing! ?
Make it a lowball sleazy offer just gimme some cash and take this thing away!
I thought you blokes like precision turbos?!
  • Like 1
