Spacers
Consensus on running a small 3mm slip on hub centric spacer to gain some clearance to the shock tower to allow a little more camber?
Stock S13 wheel nuts, haven't measured thread engagement just yet.
4 stud car so finding wheels is painful.
https://www.sau.com.au/forums/topic/469977-spacers/
I looked at using those, smallest was 10mm though so I thought I'd end up with guard clearance issues, plus then the front track will be wider than the rear, by default the rear is wider, and in my case wider again as it has the S14 rear subframe.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7823488
Checked threads, not comfortable running spacer on those.
Given how hard it is to find a square set of 4 stud 17x9, any issue with running 10mm bolt on spacers only at the front? Would mean front track was wider than rear, which is not standard.
Or could  just run them all round, keep track even and make car wider.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824770
Or another idea.
Could use hub centric 15mm or 20mm 4 stud bolt on spacer and then be able run the rear 17x9 rim i have from the other set of the same rims on the front so I can get 255 on it all round).
Seems there's plenty of guys on there using proper hub centric bolt on spacers, it;s non hub centric and slip on people don;t like.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7824779
  • 4 weeks later...
I would say no, if the car has even track width side to side there should be no impact on HICAS, maybe the rack works a touch harder as the wheel has been moved further away from the axis of pivot.
Get your rear alignment checked and inspect the HICAS tie rod ends for wear and play of you want to keep it in, otherwise, Lock it out but do it properly where you press the tie rod ends out.
https://www.sau.com.au/forums/topic/469977-spacers/#findComment-7830628
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
