Hitting a curb at 60kmh
Hey, so last night i was on my way home from work. Long story short, i stupidly caught my front right wheel against a small island and it jolted the car hard.
I was travelling at around 55- 60 kmh. The front right rim is rashed pretty hard, as i currently have stretched tyres on. I came straight home about 2 min away from the island. I'm not sure if i was being paranoid but when i pulled into my driveway (Over a bump) i heard a bad noise from the front right side that i wouldn't normally hear. I inspected today as i haven't driven it. No tyres damage, just the rim as i had stretched tyres. The wheel is rashed bad, but i can't tell if any other damage as i haven't taken the wheel off.
What do you guys recommend? I don't want to drive it and risk any further damage (Hoping it is not damaged). I'm Worried about driving it out to check if any damage.
Bearing in mind i don't have crazy money. What do you guys recommend? Please help!!!!
https://www.sau.com.au/forums/topic/469984-hitting-a-curb-at-60kmh/
First things first, jack the car up and take a look at your brakes and suspension.. Inspecting this carefully will show you is any damage has occurred. If you aren't sure what you're looking at, grab some images from google (or here somewhere). If all else fails take both front wheels off and compare the front sides of the car.
If you have done something it could be something very silly (like the guard liner dislodging) just take a look and you'll be able to spot any problems.
  • Like 1
3 hours ago, jmknights93 said:
Your alignment would be way out if you've bent anything such as the front lower control arm or rack end. So the short drive home would determine if the alignments out.
Hey guys so i can't remove the wheel until tomorrow as my friend has my trolley jack...
I took a closer look, and did as much investigating as i could. The upper ball joints on either side are fine, and from what i can see so far the springs and shocks look to be fine. I cannot check the lower ball joints or tie rods until tomorrow....
However i did find something that has worried me. I have attached the image below. There is a gap between the ball join connecting to the control arm (i think) on both sides of the car. Is it supposed to be like this? Or am i stressing over nothing? Image below
1 hour ago, The Max said:
Of course it needs to be that way ... the ball joint needs room for movement.
Thank goodness! AHAH. I took it out yesteday for about 4 hours, and i was driving real smooth. At one junction i accelerated hard and it didn't feel good, and the front right side is making creeking noises when going over bumps and dips... Any suggestions? Ill need to take the wheel off soon and suss
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
