refurbished injectors, are they usable?
Hi all.
I am budget building my r33 gtst now. Got hypergear turbo and pfc. Now looking after injectors. Planning to make 250-270rwkw.
Found these injectors on ebay. http://www.ebay.com.au/itm/6-Genuine-740cc-fuel-injectors-RR544-for-Nismo-Nissan-Skyline-R33-RB25DET-ECR33-/112089938321?hash=item1a1914b991:g:YkIAAOSwawpXq-aw&autorefresh=true
They are marked "- PROFESSIONALLY re-manufactured" and "- Spray, Flow and leak tested". I reckon they look good.
So just want to ask are they really good? Or can you recommend anything else that can do the job and is cheap?
Btw, what afm do people use on rb25 today? Still z32 afm?
Good and cheap don't really go together but in theory professionally remanufactured and tested injectors should be fine. The question is can you trust the supplier ? Are they enough of a saving to be preferred over brand new (and new technology) injectors?
If you are using Nistune then Z32 AFMs are still a good upgrade (if they are brand new and genuine) but if you are upgrading the ECU then you will be going MAP sensor
Cheap copy Denso injectors gave me bad hot starts and really bad fuel economy.
Poor atomisation, had to retard timing heaps.
They weren't made in Japan.
Had to rip em out and dyno tune all over again.
Tried to save $300, but cost me another $1000 to fix
that sucks. i will definitely avoid this...
thank you for that information.
That makes sense. So do you have some suggestion?
Thank you in advance.
Try Scotty for some new injectors that will slot into your sidemount rail
scotty nm35     http://www.skylinesaustralia.com/forums/user/63525-scotty -nm35/    https://www.facebook.com/pages/Scottys-Customs
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
