  • 3 weeks later...
On 27/04/2017 at 1:12 PM, PranK said:
Hey Johnny,
Welcome to :sau: !
Thanks PranK
On 02/05/2017 at 1:46 AM, paulzy123 said:
Welcome to the best place to be mate ?
Whats the plans?
FFP, bigger turbo and injectors, ecu, gauges, hopefully run 11 seconds on the quarter, wider front and rear guards. Oh and fix the bloody thing
  • Like 1
https://www.sau.com.au/forums/topic/470207-new-guy-in-town/#findComment-7830412
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
