Using aux input for obd2 diagnostic
Hi guys, I have been researching on this site, and have gotten a few plans, but I'm just not sure if it will work.
Will it be possible to connect an obd2 link (thinking HKS OB-LINK) with an android device, and use Torque app to display the information?
Then run that through the aux input of the navigation system to come through the popup screen, as I would rather use it for diagnostics then something as basic as fuel economy.
I am looking for an end result like the picture attached (from an r35)
Thanks
Lachlan
Edited by Lachlan S
https://www.sau.com.au/forums/topic/470227-using-aux-input-for-obd2-diagnostic/
Sure thing. Get the appropriate cable that will plug into your phone's USB to provide you with the respective composite video output and away you go. It won't look as clean and sharp as the real graphics you get from your system (or an R35) but it'll be functional. The trick will be to ensure that the phone itself will mirror the screen via the cable and not only work when you're playing videos, for example. I doubt that will be the case but it's still something you'll need to test. I know my Samsung Note4 works fine in this manner, using an MHL cable which has the USB connector for charging as well as the RCA outputs (eBay job).
Edited by The Max
Your big problem is that almost nothing will talk to the ODBII in our V35s. I am not sure anyone ever has gotten any meaningful data out of our hybrid Canbus/OBDII setup. Happy to be proven wrong though.
Getting the data/display into the factory screen is easy - the amp in the boot has an aux in (that I currently use for DTV).
Ahh thanks, i think ill grab a cheap android (all i need it to do is receive info and display the torque app), and use the composite video. Is there any examples of people doing this before?
Ah really? Damn, I think I heard of some and the OB-LINK 2 says its compatible but I'm honestly not too sure.
How does your DTV input work?
Yeah they all say they are compatible with G35s, but their wiring setup is somewhat different to our Jp V35s.
The DTV is just plugged into the AV in for the screen/amp setup in the boot.
On their website it said nissan v35 with the coupe chassis code. Some people on this website said they had it one theirs, shouldn't it be the same for all jap v35s?
Try and find proof of someone using one and getting all the OBD data to work with Torque.
Hundreds of people have tried hundreds of OBD devices (I tried a couple of different ones many years ago - none worked). If it were as easy as you say, EVERYONE would have one in their V35s.
That said, these HKS units do look good and are fairly recent maybe they will work?
But go ahead - buy all the bits, and if you can get it all to work I will applaud you and follow the exact same route :) Let us know how you go!
Thank you, ill keep digging and let you know how i go.
The only compatibility issue will be with the connector. Essentially, there are two global standards for OBD-II connectivity, though those standards aren't absolute for all and some manufacturer discretion is allowed beyond the basics.
However, it surprises me to hear that a manufacturer would alter their OBD-II connectivity between a USDM and JDM variant of their vehicles. It makes no sense, as that would suggest that my Consult III+ scan tool is made for a specific region, which they're not.
Grow some nuts, take a gamble and test the theory. Someone always has to be the guinea pig, no matter how well researched they are to minimise the loss! ;)
But go ahead - buy all the bits, and if you can get it all to work I will applaud you and follow the exact same route Let us know how you go!
Torque may not work. I have hobdrive working in my M35 stagea. I just checked in the pre defined vehicle settings and it lists 2001 v35 skyline. You can download the demo version for free to check if it works. May or may not. I use a vlink elm adaptor thing plugged into the obd port and connect to it via wifi.
Which vlink adaptor do you use? Do you have a link to it?
also, do you have pics of your setup?
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
