Self leveling light problem
Hi guys,
I've tried to find something on the form but unfortunately I wasn't able to find someone with my problem.
Long story short, I'm not using a lot my car ,so most of the time is parked in the garage. Last time everything was working fine, few days ago I went for a ride and I noticed something wrong with the headlight. When I turned them on instead to leveling at the right position they went all the way down.
Actually I know there's somewhere in the back some sensor can automatically level the headlight, but unfortunately I have no idea where is and if the problem is relative to it.
Any help would be great.
Cheers
PS. The car is a CPV35 2006
PS2 sorry for my bad English.
Edited by Loris_V35
https://www.sau.com.au/forums/topic/470369-self-leveling-headlight-problem/
Does it have a headlight height switch? If not, then check these
http://jp-carparts.com/nissan/partlist.php?maker=nissan&type=152&cartype=13&fig=253&page=15
https://partsouq.com/en/catalog/genuine/unit?c=Nissan&ssd=%24HQARW1d0BAsGAwIVOjlKShl3bWlsbD8OMBM%24&vid=19574&cid=4&uid=558440&q=
Strange that both drop, possible the height controller box died. You should be able to disconnect the motors on the headlights if so.
Thanks mate, I think I have found the part.5911885d5b5fc_IMG_20170509_1755341.thumb.jpg.72d54eec8d1f6426616cc00303748514.jpg
I tried to disconnect it and move it manually, but the headlights weren't moving.
I tried to disconnect the plug with the lights off, and when I turned the lights on, the motors didn't turn on and didn't lower the lights.  When I put the plug, back in, the motors lowered the lights down.
What do you think? Thanks for any suggestions or advice!
I'd need to get a look at a schematic to understand what's going on but I'd imagine there's a sensor, control circuit and a stepper motor. One of those three components will have failed. If it's an optical sensor, it might just need a clean with isopropyl alcohol. If it's a mechanical sensor, it'll either need a clean or replacement. If it's the control circuit, easiest approach would be to replace it but if it's just a dried out or shorted capacitor, that can probably be cheaply sorted out. If it's the stepper motor, you can determine that by feeding the appropriate pins with 12V to see if you get any movement out of it.
Again, without a schematic, hard to be sure where to begin with the diagnosis past the obvious mechanical bits.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
