4 hours ago, ActionDan said:
No problem, I know how important it is to get some feedback on the hard work.
Plus I love the sound of NA. Looking forward to you firing this up.
There has been alot of time involved, as per any project car. Although definitely enjoyed the feedback!
I'm really excited to fire it up too!
Hopefully won't be too long now.
A few photos from todays efforts guys.
Made a start on the airbox:
Made the lid, I still need to finish it off. Mount the Dzus 1/4 turn fastners on the lid, nutsert and bolt the sides and finish the duct from beside the radiator oh and of course, paint it black ?
Although definitely made some progress today which is nice. A nice change from the wiring anyhow.
Thanks for reading ?
Edited by TimmyMA70
  • Like 3
Hey guys, some more progress the past couple of days.
Made a mount to support the air intake: welding probably isn't 'insta worthy' however, it's definitely stuck on there lol.
Welded the intake temp sensor in the intake as well:
I made this 'duct' for the inlet into the airbox too, designed it so it'll pickup the air pushing around the radiator, this shot is from the inside of the box, looking towards the radiator.
Also managed to get the air/oil separators setup:
Lastly a photo of the 1/4 turn Dzus fasteners for the airbox lid. I still need to get some foam for under the airbox lid and paint the airbox and intake black too.
Thanks for reading guys ?
  • Like 4
Just a small one for tonight guys.
Painted the airbox last night and assembled it all tonight for a mockup.
I personally like the stealth black. I'm in 2 minds about the colour of the intake pipe. I'm thinking Satin Silver at this stage to keep it clean, although not in your face.
We'll see though.
My wife was having a fiddle with the camera tonight too and took a bit of a fun photo I thought I'd share too:
  • Like 1
11 hours ago, ActionDan said:
I'd be inclined to powder coat it silver, that will give a textured finish more closly matching the plenum. Otherwise, uyes agree silver would be good, and satin or matte for sure.
I agree with you there that a texture would finish it off quiet nicely.
I've in fact ordered some wrinkle silver paint. I'll give that a try first and worst case, if I'm not happy with that, I'll look at other options.
Thanks for the feedback man ?
So, small update guys. The DBW throttle body/pedal is all wired in, calibrated and working! Couldn't be happier in all honesty.
The Haltech powered up perfectly. After a swap from one CAN port to the other the Wideband is now working too. All the inputs have been setup and I only need to setup the ignition timing, fit the cleaned and flowed injectors (hopefully this Thursday) fit my driveshafts and fill the gearbox up with oil. It should be right to start then!
Oh, I have confirmed the crank trigger is working to some degree also(reading RPM)
With some luck, this weekend I may be able to get it fired up!
  • Like 2
A major update guys....
Finally got the SR fired up!
I only had one minor issue getting it to start, which was I had terminated the fuel pump in an empty slot on a Deutsch plug. However no biggie there!
Now to finish the wiring off inside the car, now I know everything works ?
  • Like 2
8 hours ago, ActionDan said:
That's a big milestone, well done.
The fact you got it running first go is testament to your had work and attention to detail.
One mis-terminated plug wire is nothing.
It certainly is a big milestone! Extremely happy with how it's come out.
Thanks very much mate! As you know there has been alot of checking and double checking hence why it's been a slow build, although it worked out quiet well in the end!
To get it running I had a spare fuel pump plug, I just terminated that and manually powered the fuel pump to get it to fire then I spent some time the following day fault finding, which ended up being very simple!
6 hours ago, Furball1982 said:
Congratulations Tim. Beautiful work.
I do love me some NA SR action!
Enjoy it!
Thank you very much for the compliments ?
I really appreciate it.
Me too! It sounds like a Massey Ferguson tractor right now, however it'll have some big mufflers in there soon enough to kill some of that 'noise' and hopefully make it sound a bit sweeter.
A little bit more information I'd like to share with you guys.
The P12 SR20VE uses top feed fuel injectors, anyhow a good mate of mine has a flow bench/cleaning station ultrasonic cleaning bath.
The engine was in fantastic condition when I stripped it for inspection and to fix the oil weep from the timing cover.
However we thought it'd be best, considering how clean everything went back together to clean and flow the injectors, as a precaution.
He did really well, managed to get all 4 injectors spot on.
  • Like 1
Hey guys, some more updates, mainly around wiring. I sussed out my inputs/outputs that were left over, there was enough to setup traction control and put both launch control and traction control on an 'on/off' switch. So I thought I might as well take full advantage of all the ECU functions.
I am using the OEM rear demister switch for the launch control (which is no longer functional) and plan on sourcing another for the traction control.
The heater box is back in, all the interior wiring has been wrapped in braid for extra protection, the dash crash bar/center console brackets have all been rubbed back and painted black due to surface rust.
All the interior is being pieced back together now. Anyway, enough writing and more photos.
  • Like 1
What do you do for a day job Tim? If you're not working on cars, you might be able to pick up a few extra coins quite easily offering out your services to those with an eye for detail and the patience and funds to get a good result.
  • Like 1
I'm a fitter/machinist Dan. I have helped other people out previously with different projects along the way. I love helping people, however the biggest reward is the ones who truly and genuinely appreciate your time.
The last guy I helped I realised the extra cash is just a sweetner, as unfortunately the appreciation was more of an expectation... I struggled alot with motivation.
However the guys who give good feedback, it honesty wouldn't worry me if I got paid or not lol
Thanks for the feedback and compliments as usual mate ?
  • Like 1
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
