  • Replies 101
  • 3 weeks later...
  • 3 weeks later...
I've got the Nissan version. I'd be happy to FTP it over to you or via any other method. However how do I get the 320Mb Toyota version? I have no website yet so can't host it anywere and none of my inbox would hold that many :(
bah. i'm uploading now. will be PMing the people who posted above before it's posted here so all the lurkers don't run the ~25 downloads we get on yousendit.com
and you all have real nissans... as if you need a nissan simulator :)
Good point! infact I have two. Still need something to do when at a loose end...
Thanks again.
Richard
here's the link for everyone else............................................................................
http://s3.yousendit.com/d.aspx?id=E48C8D72...C124F4E462F8D23
Do not click remove, do not post elsewhere. i don't think it has many downloads left as all but 1 person i pmed, or pmed me has not messaged back. i don't mind hosting it there again though... just leave it there to upload when i go out etc.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
