Advice / Input
Hey Guys i'm new to the forum and need some help if you don't mind.:banana: I live in South Africa
I currently have an Rb 25 Det lemme give quick run down on spec's.
Sub Assembly skimmed 1 mm Rb 26 pistons 86 mm COMETIC Head Gasket
Head done ported and gas flowed cams cut 270. Done by Steve Clark No Sweat Racing
Head currently has all Rb 26 parts , Valves , Quarters , Retainers , Valve Springs , Lifters etc. So Head is Solid Cams and Lifters. Head can probably rev about 8500rpm+ but oil pump is stock.
Branch build by Marius from Full Boost 3 into 2 into 1.
Turbo Garret 60-1 T4
Bosch 750 cc Injectors
Bosch 044 external and Facet in tank pump
Rb 30 Clutch and Pressure Plate
40 mm Wastegate
Custom Intake Manifold
Intercooler
Spitronics Engine Management 60-2
70 mm Exhaust
Currently has 1 Bar map on 95 ctane pump fuel. Took the car for Dyno but was spark breaking on the Dyno will replace this weekend.
Not sure if any of you have similar set ups. So this is where I need some info please car will be going back to Dyno soon:happy:
I will be Changing Fuel to 50/50 95/Ethanol
What do you guys thinjk Rb 26 pistons can take max boost?
I'm looking to try and push for 1.2-1.5 bar boost is this ok?
What Hp should I aim for safely?
If you guys can assist with any input will be highly appreciated. Sorry about the book tried to give as much info as I can:cool:
Thanks
Brian
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/
Hi thanks man. It is a 1972 Chevrolet 4.1 Limited manufactured in SA and Australia also had them.
Awesome, I'm not a huge muscle car guy so would never have managed to guess. I hope someone here can give you some guidance. :)
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836682
Thanks and I hope they will assist me. Unfortunately had to do mod in there because they never brought R32,33,34 to SA. We can only buy the engine's here or import the car which is very expensive. I would like to own a R34 Gtr Vspec though:banana::banana:
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836684
1.5 bar is nothing - do not go by numbers - your tuner should keep increasing boost until it becomes counter productive and similarly tune to max with regard to exhaust temps knock control etc. You will get what you get.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7837240
Hi Kiwi I've been busy with converting a set of coils but came across another thread discussing some of the issues other guys are having. After reading through It seems to me that I may have a similar problem. So I removed all the coils including the aluminum portion that is bolted in the middle of the cylinder head. Low and behold the hole bottom of the aluminum casing is black seems that the coils have been earthing against it when ever it spark breaks. So my car starts normal idles normal and rev up to limit when stationery also is not missing like a dead plug or coil. Only time it spark breaks it under load. So I got some liquid electrical tape with a brush and also bought some plastidip spray also for electrical insulation. I will be spraying the aluminum cover with that to insulate it so the coils does not spark against it. Also will do the coils and suppressors with the other. Worth the try I guess. I unfortunately cannot have the aluminum portion cnc'd out of plastic as the other guys did. So I will be doing that tonight possibly with put everything back tomorrow and go and test. Hopefully resolves my issue if not I have been busy with a set of other coils. Don't know if you've seen any of the threads speaking about spark break issues.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838250
Yes there are hundreds of such threads. Your fix may work for a while (gap your plugs down to 0.8mm as well) but start saving for some new coils.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838265
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
