New memeber from the Caribbean
Hello everyone,
My name is Joe Risseeuw and I'm from the Caribbean.
an island called Curacao right next to Aruba.
I own a 1996 R33 GTST with currently a 25 Neo swap.
Spec list
Microtech LT12S @8K rpm
Garrett GT3582R .82 AR
Tial 38mm
ID1000s
Walbro 400 intank to surgetank, A1000 to rail
Spool Spline drive collar
Spool billet gears in N1 pump
Edited by JoeRisseeuw
  • Like 3
https://www.sau.com.au/forums/topic/471079-new-memeber-from-the-caribbean/
3 minutes ago, JoeRisseeuw said:
Anything you guys need to know about Neo swapping go ahead and ask. First hand experience. Wiring, coils, manifolds. I got you lol
With an attitude like this, you'll be in high demand here! :)
Welcome aboard. just into any discussions you think you can help on. Technical requests are always coming through.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
