Damaged RB30 Block Repairs
Hi all,
I'm helping a friend rebuild a VL Calais. Long story short we bought the car for $2500 as a bunch of pieces and a rolling shell. Most of the car was there and we have managed to put it all back together. I should add that we are by no means mechanics, so please excuse my ignorance where it may appear.
We have managed to start the car and it does move under its own power after several months of rebuilding it, however, one of the exhaust manifold studs was bent and had been poorly re-tapped. Initially we believed this would not be an issue, however, it leaks radiator coolant from the re-tapped stud area (we just left the exhaust off the car for initial tests).
We have since learned that this cannot be repaired quite as simply as we had hoped and the block may need serious work to be any use to us. I believe that there may be coolant leaking into cylinder six. There is no water in the oil (we've checked twice). Obviously this is an issue and we are in the process of stripping and pulling the engine out for reconditioning. The coolant absolutely pours out of the exhaust port of cylinder six when the engine is running. I'd suggest it could empty the coolant from the car within 15 minutes if left to run.
My query here is, in the event that we pull the engine for re-condition and cylinder six is in good condition, is it going to be possible to repair the block of the engine?
We could simply have someone re-work the block and re-tap the stud, but does anyone know the effect that might have on the water path through the block? I'm concerned that if we attempt a repair we will re-direct the coolant path into the cylinder itself or some other area where we don't want coolant.
Can anyone offer their opinions on this matter or does anyone have experience with this type of problem? (Pictures to follow).
https://www.sau.com.au/forums/topic/471080-damaged-rb30-block-repairs/
well the good news is that the exhaust ports and their studs go into the head, not the block.....which means you probably have a perfectly good (and valuable) rb30 block.
the single cam rb30 head is probably worth about $3 including postage so you may be able to just swap it for another if you are trying to get it going cheaply.
  • Like 1
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
