Any members on here go to roll racing? I went to the last one as a spectator and went to this one last night as a support vehicle, but ended up entering and having a few runs...
And I have to say, had a ball, great fun and not too hard on the cars, I was rolling up to 50km/h in second gear then planting it at the tree, shifting at 7-7500rpm, car did very well, I was hitting 200-220km/h by the finish line.
  • Like 2
https://www.sau.com.au/forums/topic/471328-roll-racing/
Ive entered once before over here in Perth, The night was great and I enjoyed beating on the new setup but with traction issues and an old H pattern I was far from competitive, Its ashame it would seem the track over here at barbagallo is abit shorter 50-100m roughly then the eastern states.. doesnt give me enough time to catch back up after spinning 1st and 2nd. Good fun taking the misso and some mates for a blast though.. once my roster lines up again ill be keen again for sure...
Edited by azzada1
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7841400
hey mate think i saw you run a few times, I have the black r33 gtst- LETZGO plates.
Edgar's r33 won the event with his new tune, stupid quick.
Haha, I saw your car, very nice, and didn't Edgar's car have done mumbo! I'll def be doing that again, just got to iron out the little issues. Next time I see you, I'll come say hi
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7842984
Sounds good mate, I'll do the and if I see you. You going next Friday? I went last night to roll drags but after few runs getting boost cut so gotta sort it out
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843039
Yeah I might come out this Friday, good fun watching the cars, don't think I'll enter though, I have to sort my box out, might see if I can get a support vehicle pass and bring the old girl out
Any idea what's causing the boost cut?
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843183
At first I thought I blew the plenum piping off, cause it's happened before and felt the same.
Wasnt it, then got under the car to make sure I hadn't melted away my wastegate lines cause it dosed like 3 times consecutively. No luck there. Decided to test drive it on street and ran like a champ. One of those things, maybe just ecu went into protection cause of boost creep on such a cool night. Will just have to monitor and see what happens.
whats going on with your box? Mines on it's way haha
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843249
Mines just got a noisy input shaft bearing, I bought a box on the weekend, going to take it to Award and have it rebuilt and put that in, then once I got mine out I'm going to have it checked to see if it actually has been upgraded to 33 spec, then I'll price up going a ppg gear set and billet flex plate. I'll build my box the way I want then drop it in with a Nismo twin plate clutch next year some time
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843292
I'm not making huge power but just want it reliable. Making 360awkw but I'm changing exhaust (going custom 4' stainless) going to up the boost and might go flex tune. Hoping to be up around 450awkw if I go flex or 400 ish on pump fuel
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843370
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
